Old 03-31-2008, 09:25 AM   #1
Hnasko Racing
Question Electric and Air Shifter?
Whats the difference between an electric shifter and an air shifter.
I'm guessing you have to re-fill an air shifter, if you do then where do you re-fill and what type of air?
Just Normal air that goes into tires? or Something like the air that goes in Paintball guns?
educate me =)
Hnasko Racing is offline   Reply With Quote
Old 03-31-2008, 09:47 AM   #2
Keith 944
Keith 944's Avatar
Default Re: Electric and Air Shifter?
air mostly refers to C02. if you all readdy have an air t-stop, then an air shifter can be tied into the same supply line.
Personally i use a Biondo electric selenoid shift, it only uses 1 amp. Some use a lot more amps. these are the major differences, it comes down to preference.
Old 03-31-2008, 09:49 AM   #3
Keith 944
Keith 944's Avatar
oh yea, forgot to mention, it can sometimes be a bear to find a C02 refill when you need it. i keep a spare bottle.
Old 03-31-2008, 11:15 AM   #4
Bob Verwold
Bob Verwold's Avatar
Also with the air I would recommend getting a solenoid that shuts off the air when the car is shut off. Some times you forget to turn it off, yes it happens!
Bob Verwold is offline   Reply With Quote
Old 03-31-2008, 11:28 AM   #5
Hnasko Racing
Thanks guys, awesome.
Just trying to educate myself for buying a future dragster. =]
Old 04-12-2008, 09:08 AM   #6
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I use an air shifter and am very happy. You re-fill them at Paint Ball stores for anywhere from $2 to $5 and they last a long time if you remember to turn them off. The solenoid valve is a good idea. It's embarassing to go down the track and it doesn't shift cause you forgot to turn on the bottle. I keep a note on the dash, "Air Bottle?".
Floyd Staggs 787 SST
Old 04-12-2008, 10:22 AM   #7
Carl Juliano
Carl Juliano's Avatar
Liked 64 Times in 25 Posts
I've been using an electric shifter for years, never had a failure, never runs out of air....lol
Carl Juliano TS 1275
John Juliano SG 151
Carl Sr.
Carl Juliano is offline   Reply With Quote
