Old 03-26-2008, 06:12 PM   #1
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Default 540, 555, 482 BBCs, Trannys, Other Parts For Sale
MOTORS & RELATED PARTS
540 cid BBC Shafiroff motor - Merlin block, Dart heads, Callies crank, all the best parts - $9,000
555 cid BBC - Dart block, AFR heads, Callies crank, Hogan sheet metal intake, all the best parts - $11,000
482 cid BBC PARTS - Brodix 2X heads, Venolia pistons, aftermarket steel rods, other miscellaneous parts - Add your crank, oil pan, manifold, and carb and go racing - $3,800
TRANSMISSIONS & RELATED PARTS
Competition Transmissions Powerglide - 1.80 gear set, TCI pump, Pro Brake, good input shaft, deep pan, shield, and flywheel shield - $1,500
Competition Transmissions Powerglide - 1.76 gear set, Pro Brake - $700
TCI & Hughes Valve Bodies - All New - Qty. 3 - $200/each
TCI Powerglide Pump - New - $350
8" Torque Converters - Qty. 2 - $400/each
9" Torque Converter - New - $800
MISCELLANEOUS PARTS
Weld Magnum Drag Wheels - 15 X 12" - Cost $380/each new - $450/pair
Centerline Warrior Wheels w/Mickey Thompson 26" Tires - 15 X 4" - $400/pair
4.57 Rear End Gears for Ford 9" - $75
Val Hedworth Q-Jet Carb - $400
Crower Titanium Connecting Rods - NEW IN BOX - 6.570" long, 0.990" Pin, 2.200" Journal - $1,000/set
Strange Aluminum Ford 9" Center Section - Small Bearing Bore - $290
If interested, please call Billy Leber at (716) 359-5457. I'm posting these for him, and don't know the first thing about anything listed here, so e-mailing me would just be a waste of your time.
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
