Old 03-26-2015, 07:50 PM   #1
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default New Eliminator proposition
Proposed "New Eliminator" classes
First of all, in order to attempt to create a new eliminator class, it has to
be friendly for NHRA to administer. My most recent "tear down", was a 4-5 hour experience.
What I propose is a "New" modified production eliminator. Relatively easy to enforce and administer as compared to the current "stock and super stock" cars…, a "tear down" would amount to pumping the engine for cubic inches, fuel check, measuring the carburetor(s) and weight. This should amount to about 15 minutes, instead of 4 hours.
I propose that it works something like this. It would be run CIC like comp. Divided into 2 types of cars. First set of cars, restricted to a certain size carburetor (I recommend a 600 CFM), and 9 inch tires.
The second set would be multi-carburetor and maximum of a 14" tire.
Every car would be classed based on cubic inches to weight. So, a multi-carburetor car with big tires would be AA/MP, BB/MP, CC/MP and so forth…..while a single carburetor car with 9 inch tire would be A/MP, B/MP, C/MP….and so forth…based on cubic inches to weight…....down to a class for 6 cylinders and 4 cylinders, both having single and multi carb designation.
So, very likely, you would have approximately 18-20 different classes competing in one eliminator category.
IMO, all cars need to be "door slammers", without any tube frame components. Same engine manufacturer as per car. (Chevy car, Chevy engine, etc.) Absolutely no fuel injection, turbos, or blowers, just complicates the process. Fiberglass components allowed because it is a cubic inches to weight proposition.
A lot of details would need to be worked out obviously, but I believe that NHRA would be receptive to an Idea that takes "Man Hours" and expenses out off the process, and keep it simple.
What do you think?
