Old 03-30-2015, 06:26 PM   #12
rognelson777
Liked 135 Times in 74 Posts
Default Re: New Eliminator proposition
Originally Posted by Alan Roehrich View Post
Make it really easy. Make all the cars weigh 3200# plus 170# for the driver. I'd skip the "two types of cars" to keep it simple. Everyone gets one (4150 series) carburetor and 14"x32" tires. Five single carburetor classes, five indexes. Easier to factor and police.
A: 470 cubic inches maximum (440 minimum), canted valves, with a 1050 carburetor.
B: 420 cubic inches maximum (390 minimum), inline valve true wedge, with an 950 carburetor.
C: 360 cubic inches maximum (350 minimum), inline valve true wedge, with a 850 carburetor.
D: 305 cubic inches maximum (285 minimum), inline valve true wedge, with a 750 carburetor.
E: 300 cubic inch V6 (minimum 270), inline true wedge, 750 carburetor.
Cast iron OE supplied block, any OE supplied cylinder head, cast intake, steel connecting rods.
NHRA approved carburetors.
Clutchless transmission, maximum 5 forward speeds, 14"x32" tire, back half, fiberglass hood only, factory glass. For automatics, 150# weight break.
Pump for displacement, anything suspect comes apart. Any compression ratio, any valvetrain, any porting or polishing allowed.
Here is a outlaw heads up class that uses the rules below It is called ultra street, yes they do run against power adder classes, some 1/8th mile some 1/4 mile
N/A WEIGHTS:
N/A Inline head – 2650
N/A Non-Inline head – 2750
N/A Buick/Olds/Pontiac - 2975
N/A (big block with 9.8 standard deck height and conventional head) 3000 lbs. (add 2.5 lbs per cu in over 589)
N/A (big block Ford with standard deck height and conventional head) 3000 lbs. over 589 add 100 lbs.
N/A (big block with tall deck height and conventional head) 3050 lbs. over 589 add 100 lbs.
N/A (big block with 9.8 standard height and big chief head) 3075 lbs. (add 2.5 lbs per cu in over 589)
N/A (big block with tall deck height and big chief head) 3100 lbs. over 589 add 100 lbs.
N/A (big block Ford with standard deck height and non conventional head) 3125 lbs. over 589 add 100 lbs.
N/A (big block GM with Symmetrical port/non conventional head) 3125 lbs. over 589 add 100 lbs.
N/A (big block Ford with Pro Stock/Symmetrical type cylinder heads) 3225 lbs. over 589 add 100 lbs
GENERAL:
- No Billet cylinder heads/blocks
This past weekend in Memphis $2,500 win, $150 entry
rognelson777 is offline   Reply With Quote
