Old 07-05-2018, 09:33 AM   #41
Ed Wright
Ed Wright's Avatar
Default Re: Wheel Studs
I have Moser Wheel Studs!
That good enough?
D
5/8"?
Ed Wright 4156 SS/JA
Old 07-05-2018, 01:20 PM   #42
Bobby DiDomenico
Liked 101 Times in 52 Posts
5/8"?
I think his issue with going to the large drive studs is factory style wheels will not fit over them. Then it requires them to have another set of race wheels to allow for storing/moving the car when the drag tires are off of it rather than a set of stock style wheels.
Old 07-05-2018, 02:14 PM   #43
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by james schaechter View Post
I really think something is not right with the wheel vs the lug nut perhaps. So what if the shank was too long and bottoming on the stud ever so slightly? The result would be a wheel that was not being clamped as tightly as you think. It could allow the wheel to work on the studs and eventually break them. Maybe this came up before. You could face the shank on the lug nuts to shorten them up a touch if they were close.
Examined everything..
Lug Nuts were all fine and not Binding.
But several if the Washers were deformed.
Installed new Moser Studs and Steel Washers.
Cleaned the washer surface, replaced a few Lug Nuts.
Going to be more attentive to safety aspects.
Will check then with a Torque Wrench before each race.
Dan
Old 07-06-2018, 09:05 AM   #44
Bobby DiDomenico
Dan,
Did you ever measure the wheel center thickness and the lug nut length from washer to end?
Old 07-06-2018, 10:31 AM   #45
Ed Wright
Ed Wright's Avatar
Bobby, they can be drilled.
Old 07-06-2018, 12:17 PM   #46
Dan Fahey
Dan Fahey's Avatar
Dan,
Not measured...used a piece of gum !!
Plenty of room.
D
Old 07-06-2018, 02:42 PM   #47
racecraft
seriously , a piece of gum? Unbelievable.
racecraft is offline   Reply With Quote
Old 07-06-2018, 03:26 PM   #48
Dan Fahey
Dan Fahey's Avatar
What is wrong with that?
Works for Valve and Piston clearance.
Touch of WD30 pack it around the Stud.
If Clay was available would have used that.
How would you have done it?
Sheesh!
D
Old 07-06-2018, 07:07 PM   #49
RULER
Liked 58 Times in 18 Posts
Now you know why he is having trouble.......
RULER is offline   Reply With Quote
Old 07-06-2018, 08:53 PM   #50
racecraft
Now days they have these things called measuring tools. Surely you have seen a tape measure ? And who uses gum to check valve clearance on a racing engine, because I want to stay away from them.
