Old 01-06-2025, 03:02 PM   #11
goinbroke2
Liked 405 Times in 158 Posts
Default Re: Lifters In Stock Eliminator
I run flat lifters and am super paranoid about break in procedure. 50# on the seat and ensure it fires(timing/fuel/fans/etc) run for 30-45 minutes 2-2500 rpm. I have never in my life wiped a cam and don't plan on it now. If I do, it will not be because of me.
Pull the 50# springs and Install correct springs, good to go.
Jim Miller
103 U/SA
Old 01-06-2025, 03:42 PM   #12
GTX JOHN
Liked 2,490 Times in 700 Posts
My understanding is that the quality of the cast core (If you still use them)
has deteriorated significantly in the last number of years. the "CWC"
casting cores are extremely difficult to impossible to find anymore.
Dozens of Horror Stories on the forums.
If the lifters do not rotate, the cams go flat in a real big hurry!
John Irving
741 Stock
741 Super Stock
Old 01-06-2025, 04:31 PM   #13
JP1738
JP1738's Avatar
Liked 1,237 Times in 351 Posts
It is real SIMPLE, your 305 DID NOT come from the factory with roller lifters ?.For Pete?s sake ?..
I don't think it's that simple. Is there a significant performance advantage to roller lifters that I don't know about (outside of reliability of course)? The engine doesn't have factory rods/pistons but they are legal as long as they are the right size, why not put better lifters in it too?
I genuinely do not understand. If you are trying to say that running flat tappet cams keeps the racing more pure to it's origin and makes the entry level more difficult and punishing to choose that combination, then just say that. I may not like it, but at least it's a fair point. After all, I chose the combination that uses them, now I have sleepless nights because of it.
Frankly, I like the idea of using newer technology to improve longevity and my quality of life lol.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 01-06-2025, 05:03 PM   #14
GUMP
Liked 2,361 Times in 558 Posts
I don't think that anyone is being punished. The combinations are what they are.
I feel that a roller profile would most likely be quite a bit more aggressive than a flat tappet.
My point in posting is not to push for a change, but to see if it is really an issue. Want and need are two entirely different things...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 01-06-2025, 05:23 PM   #15
JP1738
JP1738's Avatar
Maybe punished gives the wrong connotation. Seems like you see what I'm trying to say anyway.
In my very limited experience, flat tappets are fine to stay, but I'm not one that has experienced flat tappet failure...yet.
Dawson Pauley
Old 01-06-2025, 06:23 PM   #16
Liked 10,884 Times in 2,255 Posts
To get stuff to live Jerry and I (mostly Jerry) made a break in fixture for our cam and lifters.
Old 01-06-2025, 07:11 PM   #17
pmrphil
Liked 348 Times in 152 Posts
But then again, John, if the lifters don't rotate, most likely the cam was ground incorrectly, probably not enough (or too much) taper on the lobe.
Luckily Mopars have a larger diameter lifter, that's a plus.
Phil Molski
PMR Performance
S/C 1623
Old 01-06-2025, 08:07 PM   #18
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
While they are called flat tappets, they are not, and they need to be matched to the amount of taper on the lobe.
Stan
Old 01-06-2025, 08:15 PM   #19
Frank Castros
Liked 2,753 Times in 974 Posts
If Charlie Wescott is listening this may be an opportunity for Militia to make some hay.
Old 01-06-2025, 08:19 PM   #20
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Frankie, welcome back
