Liked 7,938 Times in 1,519 Posts
Liked 2,354 Times in 554 Posts
So, is the inferior parts thing a myth? Is it still possible to build flat tappet combinations that will be reliable with new parts that are currently available? Not older parts that you just happen to have.
Daren Poole-Adams NHRA Stock/SS 2007 |
Liked 460 Times in 59 Posts
It's a combination of things, but IMO the biggest factors are lubrication, ramp speed, and valve spring pressure.
Light oils, windage reduction, aggressive ramp speeds, and higher valve spring pressures, all improve performance but reduce reliability. The main culprit of flat tappet failures in Stock was allowing increased valve spring pressure. Careful what you wish or lobby for. The rule of unintended consequences never goes away. |
Liked 392 Times in 153 Posts
I run flat lifters and am super paranoid about break in procedure. 50# on the seat and ensure it fires(timing/fuel/fans/etc) run for 30-45 minutes 2-2500 rpm. I have never in my life wiped a cam and don't plan on it now. If I do, it will not be because of me.
Pull the 50# springs and Install correct springs, good to go.
Jim Miller 103 U/SA |
Liked 2,485 Times in 697 Posts
My understanding is that the quality of the cast core (If you still use them)
has deteriorated significantly in the last number of years. the "CWC" casting cores are extremely difficult to impossible to find anymore. Dozens of Horror Stories on the forums. If the lifters do not rotate, the cams go flat in a real big hurry!
#6 | |
Liked 348 Times in 152 Posts
Luckily Mopars have a larger diameter lifter, that's a plus. ![]()
Phil Molski PMR Performance S/C 1623 |
#7 | |
Liked 734 Times in 385 Posts
While they are called flat tappets, they are not, and they need to be matched to the amount of taper on the lobe. Stan |
#8 | |
or sloppy machining that causes them not to rotate. Flat tappet lifters are also not flat either (At least to start with hopefully)
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 01-06-2025 at 11:03 PM. |
Liked 704 Times in 281 Posts
Built a 350 Chevy for a hobby stock dirt car. He insisted the hole in lifter face was the way to go. I said that its not a great idea. 2 Cam lobes and 2 lifters were worn out. It took the center of the lifters and put major cups in face with the .015 hole opened to around .080 hole size.
Anyone take their lifters and cams and get frozen. Works great on valve springs and brake rotors. |
#10 | |
Liked 1,187 Times in 338 Posts
I genuinely do not understand. If you are trying to say that running flat tappet cams keeps the racing more pure to it's origin and makes the entry level more difficult and punishing to choose that combination, then just say that. I may not like it, but at least it's a fair point. After all, I chose the combination that uses them, now I have sleepless nights because of it. Frankly, I like the idea of using newer technology to improve longevity and my quality of life lol.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
