Old 01-02-2025, 12:21 PM   #11
JP1738
JP1738's Avatar
Liked 1,341 Times in 365 Posts
Default Re: New to .90 tech forum
Just based off what I've read, I've yet to see a highly competitive combo in SG hitting the .400 tree on small tires. I do not think you can reliably hit the tire hard enough to get a hold of the tree unless you're reaction time is inhuman. SST is the way to go, you'll have more than enough time to plant the tire softly on the .500 tree. Also, the safetly changes that occur at 135 are really not a huge deal if you already take it seriously. Window net, gloves, closed face helmet are the main changes, but most people have that stuff anyway. 1000hp in SST at 2800# (min weight) would probably get you in the neighborhood of 150mph. If that's the case, the safety changes do become rather large. HANS device etc.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 02-23-2025, 04:12 AM   #12
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
How much does the safety change From Super St to SG ?
Jake Biermann
Old 02-24-2025, 11:24 AM   #13
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 226 Times in 97 Posts
No change in the safety rules at all.
Now, if you are on the slow end of Super Street (under 135 MPH) you can wear a thinner fire suit, no gloves, no window net) that you could never wear in SG.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 06-11-2025, 10:27 AM   #14
WKCOOK
Liked 5 Times in 5 Posts
Good day all. My new username is wkcook, not warrenc. (lost password) I have my motor back. Many thanks to Bruce @ ABS Competition Engines in Regina, Canada. Any suggestions on PG transmission builders in Canada or along the northern USA border states?
88 Mustang
533 BBF N/A
WKCOOK is offline   Reply With Quote
Old 06-12-2025, 04:19 PM   #15
JP1738
JP1738's Avatar
Not to be that guy that throws out a useless recommendation, but the best powerglide builder I've run across and most reasonably priced is Bernard Weaver at Weaver Automotive. I'm sure if you can get linked up with him he can ship you whatever you need. I've had his transmission in my car for over 10 years and made over 2000 passes. No signs of wear. I believe he lives somewhere near Richmond Virginia
Dawson Pauley
Old 06-12-2025, 04:42 PM   #16
BIGG18c
Liked 43 Times in 18 Posts
Bishop's Performance in Grand Rapids Minnesota looks to be fairly close to you. Chris is an excellent .90 racer and transmission builder. He should be able to build you exactly what you need. I believe he is a Hughes distributor as well.
Grant Christianson C521 S/G,S/C, S/PRO
BIGG18c is offline   Reply With Quote
Old 07-02-2025, 02:36 PM   #17
WKCOOK
Thank you.
88 Mustang
533 BBF N/A
Old 09-11-2025, 07:07 PM   #18
WKCOOK
Default Update New to .90 tech forum
Attend our 1st event, WDRA @ Saskatchewan International Raceway. couldn't get to NHRA event in same time frame.
Best ET 9.51
Best MPH 138.83
Best 60' 1.32.
wheels spin a bit on launch.
wheels spin on rim 1/4" every pass.
WDRA "Licensed"
Intent is to NHRA License at BIR Sept.19-21.
Need to get more seat time and work on front Dble adjustable strut settings, delay box # and my reaction time.
Car very consistent (IMO).
11 passes in total including licensing.
Then we start the steep learning curve of managing a throttle stop set-up.
88 Mustang
533 BBF N/A
