Old 12-21-2022, 11:09 AM   #11
Billy Nees
Default Re: 65-85 under.
Originally Posted by SDT1DYI View Post
I would be in favor of a personal index adjustment in heads up situations to level the field.
Steve Teeter Stk/SS 620
OH YEAH! And the Choir Boys in Stock Eliminator won't manipulate that! Just look at the mess in Comp!
Billy Nees 1188 STK, SS
Old 12-21-2022, 11:43 AM   #12
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: 65-85 under.
My combo is rated from the factory at 365.
I would be in favor of treating my 365 factor the same as this one:
Mopar 426 365 291 295 1964
Old 12-21-2022, 02:22 PM   #13
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Would you then be in favor of running a manifold from an Olds that came on late 50s engines along with an AFB that flows 575 cfm in place of your QJ that flows 800 cfm. Would you give up the valve to piston clearance and long stroke that allows you so much more cam than the 426 SW can run.
Old 12-21-2022, 03:17 PM   #14
442OLDS
442OLDS's Avatar
So the combo just got horsepower and is still rated 70 horsepower below the factory rating.The Oldsmobile driver just "needs to work on the car".
BTW,I don't get the 800.And it was checked at St Louis by tech.
Gotcha.
Old 12-21-2022, 05:09 PM   #15
Paul Precht
Gotcha.
They bring a flow bench to tear down, never saw that.
Old 12-21-2022, 05:20 PM   #16
Steve Stasko
Liked 287 Times in 146 Posts
Why would anyone run the 2206000 intake, when you can use a '68-71 440 HP intake? I certainly wouldn't use the 516 heads either when I could use a 915 that's 19 cc larger on the intake side...
For what it's worth, I have a '65 Coronet 426 SW car, and have had no issue finding those intakes or heads that they were originally equipped with.
Steve Stasko is online now   Reply With Quote
Old 12-21-2022, 05:29 PM   #17
442OLDS
442OLDS's Avatar
I'd probably use the 2206000 because you could buy one for $135.lol
https://www.bonanza.com/listings/196...Date/842193838
Old 12-21-2022, 11:04 PM   #18
littlemanjoe
Liked 75 Times in 28 Posts
The Mopar's have always been at a disadvantage. We are stuck running 50 and 60 year old intakes. They make aftermarket heads but good luck getting them. Very little to no aftermarket blocks or cranks.
I guess we'll struggle through.....
littlemanjoe is offline   Reply With Quote
Old 12-22-2022, 08:39 AM   #19
Billy Nees
OK everybody! Let's have a pitty-party for all of the poor Mopar Racers! Maybe take up a collection.
At least the FFFord Racers don't whine.
Old 12-22-2022, 03:11 PM   #20
littlemanjoe
Easy there Billy man, I'm just rattling your chain.
But you have to be honest, the Mopar folks have the least amount of parts to choose from. When you go faster than 75 mph, it takes some good parts and pieces.
Have fun and may the force be with you.
