#11 |
Liked 1,026 Times in 281 Posts
That's not gonna happen, and it shouldn't. We just had this thread a while back. While some would run a cheap pump gas, others would be back to exotic mixtures to get every ounce of hp possible, which I would probably take advantage of also. Fuel check is to keep the playing field level. If you want a cheaper fuel, run Sunoco blue. It's close to half the price of some VP fuels.
Duane Hoven 1342 SS/GT |
#12 | |
Guest
Posts: n/a
Henry, It’s much cheaper buying it by the drum then 5 gal cans. The Hazmat charge is the same, whether it’s 5 gallons or 54 gallons. C25 used to cost me 17.00 a gallon in a 54 drum. It was at least 20 if not 25 in a 5 gal can. It’s definitely the way. I’ll never buy it any other way, especially if I’m running a complete season. I know that’s not for everyone though. I also heard about VP raising their prices this year. I haven’t bought my fuel yet this year, so I don’t know how that is going change.
#13 | |
Liked 109 Times in 18 Posts
#14 |
Liked 51 Times in 30 Posts
hi,
I can run pump gas on the dyno?? mopar 400 8.1-1 comp. I have 2 pails of c-11 saving for march t/t |
#15 |
As you know Ryan, I had good luck with the surge, we need to follow up with Sunoco and NHRA and get it back on the list.
#16 |
Liked 974 Times in 310 Posts
Was Surge better than sunoco blue ?
#17 |
#18 | |
Liked 520 Times in 176 Posts
You are absolutely correct. I did buy some to make sure I would have enough fuel to finish the dyno session. I do buy fuel by the drum and it is cheaper per gallon then the 5 gallon containers. I was just showing the price increase a couple of months made and it looks like it will increase again. Yes, we went through the pump gas / race gas situation, no need to keep beating that horse. Unfortunately this is a small part of a big picture and I'll keep going as long as I physically can. Have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
#19 |
Liked 557 Times in 217 Posts
Atco's fuel prices were very high for the last few years.....
$100 for 5 gals of any high octane VP or Sunoco when they had it. Much cheaper buying from better sources and larger amounts.... C-11 was $1 more than C-12 the last time I was running either fuel....and for me made very little difference.. The hard part is getting it and transporting it in drums, always has been but it saves a lot of money.
#20 |
Liked 230 Times in 94 Posts
There is a Sunoco dealer in Oakhurst that became a full line VP dealer last fall. Call Phil @ 732-496-0098,and see what he can do. He also races and tries to help on prices. John Kissel
