#11 | |
Liked 237 Times in 126 Posts
I think a member can post a link to the Products List, but I'm not sure. PM me with an email and I'll send you a copy of mine, but not the rule book. It's a PDF file. Dale
#12 |
Liked 33 Times in 16 Posts
You may have to register to view... http://www.classracerinfo.com/Engine...2366&MAKE=Ford
Rich Taylor I/SA - 321 |
#13 |
Liked 240 Times in 112 Posts
OK, I'm still a newb at this, but who does documents flow on carbs ?
Dave Noll, EF/S ,?/SA 6526 |
#14 |
Liked 4 Times in 1 Post
As stated by many, get a rulebook. deff. can not run a tubular k member, has to be stock, 4 bangers and V8 work, make sure you get the factory control arms with the factory k member. I read an article in MM&FF years ago about a place in central FL that builds T-5 transmissions to handle more power, probably 10-12 years ago article. Jericho's and Liberty's are the choice but a Doug Nash/Richmond 5 speed can work if you find one cheap. Liberty can trick it out. Heavier than J or L. Find as many older articles on Project Stocker that Evan Smith built in MM&FF.
#15 | |
Liked 275 Times in 76 Posts
Competition Carburation uses a flow bench. That's who blueprinted my carb.
#16 |
Liked 348 Times in 79 Posts
So it looks like the carb needs to be :
E5PE-BMA OR E5ZE-GA MANIFOLD: E4ZE-EA & GA......ALUMINUM?? HEADS: E5AE-CA & GA Am i reading this correct? |
#17 |
You're right on the intake and cyl head #'s. All of the intakes for these are aluminum as well.
As long as the carb is a 4180 it does not have to be a year specific carb anymore. So don't get hung up on the carb casting number unless you're restoring. My car has a GF5R, the T5 G-Force would be a huge waste of money for how much they cost, as they do not have inline shifters. Sean
#18 | |
Liked 251 Times in 125 Posts
I put his innards in my '87 street/strip Mustang w/ a T5 about a year and a half ago. I don't know how his stuff would fare in a Stocker, but he's a great guy to deal with. Plenty of info on the web about his A5. (A T5 with his stuff in it.) He'll sell you the parts, or an entire trans. |
#19 |
Anyone know if a boss service block is acceptable? It's a D1 or d2, haven't looked in a long time.
#20 | |
But ask your local tech. Ive been told that blocks aren't critical as long as the specs match the application. Dale
