Old 09-14-2016, 06:04 PM   #8
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: 1985 Mustang GT help
I have a bolt on ready to go 4180 carb with flow documentation from my stocker if interested, along with a box of spare carbs. The crappy thing that Ford did to the 83-85 engines, the intakes are casting # year specific. I am sure they did the same with other years too.
You can't go wrong if Rory has extra heads, intakes and carbs, to not pursue making that deal!
Another clarification for the 85 GT, its a stick only combination. The block is not casting number specific. A Mexican block or approved aftermarket block is ok. Hydraulic roller cam conversion kits are legal. Front and rear suspension is very rules dependent. No coilover conversions, or aftermarket K-members.
The initial investment in a good trans, bellhousing and clutch/flywheel may be scary. But those components will last for many years with a lot of abuse behind these motors.
Good luck,
Sean
Sean Marconette
84 Mustang
5060 SS/N
