Old 12-18-2014, 12:35 AM   #11
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: C4, C6 Question
Originally Posted by jmantle View Post
If your looking for an inexpensive way out and don't mind running the stock ratio, the early 64 -66 C4's had a brass and steel washer at each side of the planet gears and would stand up much longer than the steel washer only later sets.
Jim Mantle V/SA 6632
Good thought,Jim. I don't think I've seen one like that. Thanks.
Dave Noll, EF/S ,?/SA 6526
Old 12-26-2014, 04:27 PM   #12
Dave Noll
Dave Noll's Avatar
OK a little twist on the question. How well do C-4's hold up behind a 460 in a HEAVY car, assuming I can find one of those D5 bellhousings. (the c4 in my cougar has 11 clutch plates & .005 - .010 clearance per plate.)
Old 12-26-2014, 04:57 PM   #13
fordteacherguy
Liked 160 Times in 51 Posts
Dave,
My mustang convertible weighs 3610 minimum and I have run it as heavy as 3675 with no c-4 problems with a lot less clutch plates than what you are using. If you were going heavier, you might just go 6 pinion FWD planetary with standard ratio if you need extra torque capacity.
BTW, I left you a PM.
Brian
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 12-26-2014, 05:35 PM   #14
Dave Noll
Dave Noll's Avatar
4680 in "O" (not my cougar)
Old 12-26-2014, 07:20 PM   #15
Dave Crysler
Don't know if it will work for you but RJ Sledge has a 2.92 gearset for trade or maybe sell in parts thread now.
Dave Crysler is offline   Reply With Quote
Old 12-26-2014, 09:06 PM   #16
"N" and "O"...spells NO!
