Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 09-30-2011, 09:25 AM   #11
randy wilson
Liked 22 Times in 22 Posts
Default Re: rpms past peak
Thanks Charlie. I don't pretend to know all the answers, and I also realise guys who run minature pro stock, which is what comp is. We run our best shifting at 9,700. Peak is 9,300. It doesn't fall off much, but it starts it's downward trend. Our best pass to date is only .001 under the nhra index, so we are no threat. If I was younger, I would try a little harder then I do now days.Ha! But we have fun trying. We have ran .9 under the ss index, but that's a whole nother ball game. Thanks guy.
don,t have one
Old 09-30-2011, 09:32 AM   #12
randy wilson
Sorry. I meant to say I realise guys in comp are a bit smarter then most.
don,t have one
Old 10-03-2011, 02:37 PM   #13
david ring
david ring's Avatar
We can't be that smart-after all, we do run comp!
david ring is offline   Reply With Quote
Old 10-03-2011, 06:08 PM   #14
randy wilson
HA! HA! Good one!
don,t have one
Old 10-10-2011, 06:42 PM   #15
Rich67stang
Liked 116 Times in 27 Posts
I have a 304 ci ford in ss/modified. The dyno sheet shows the motor making power @ 9900 rpm and never falls off. where should I shift and/or is the cam putting the power in no-mans land. Thanks
Rich67stang is offline   Reply With Quote
Old 10-11-2011, 09:10 AM   #16
randy wilson
That's where I would think you would want it. That's way better then our motor for SS\Mod. I would keep going on the dyno and see. You probably have a really good piece.
don,t have one
Old 10-13-2011, 04:56 PM   #17
MOTORSPORTS Innovations
MOTORSPORTS Innovations's Avatar
Liked 15 Times in 2 Posts
Powerglide - 800 (it's likely going to go to stall RPM)
3 speed - 600
4 speed - 400
The G-meter graph from the Racepak will be your tuning tool.
www.motorsportsinnovations.com
MOTORSPORTS Innovations is offline   Reply With Quote
Old 12-06-2011, 11:00 PM   #18
Jeff Lee
Jeff Lee's Avatar
I only run Stock & Super Stock so excuse my ignorance. But what I see missing from this conversation is any reference to the type of transmission and gear ratios within the transmission. And I believe that is critical on the shift RPM.
Jeff Lee 7494 D/S '70 AMX
