Liked 20 Times in 15 Posts
good for only two years if this is approved?
So would that make my scattershield I just purchased(without an adjustment hole) good for only two years if this is approved?
What they are saying is 6.1W would require re-cert sooner than the 6.1. W for "window"" bellhousing.
See www.quicktimeinc.com for their bellhousings. What Jim said was correct, nice, light bellhousing. More floor space too.
Jeff Lee 7494 D/S '70 AMX |
#4 | |
Just like "PICKLED" heads and intakes I guess !!! |
Liked 1,583 Times in 582 Posts
Some years ago, I challenged SFI on the 2 year requirement. I collected data from S/SS and Comp stick shift racers. Also, I took a Lakewood bellhousing, did extensive structural analysis and gave the data to NHRA.
After a telephone discussion with NHRA, they asked me to submit and talk to SFI. What a joke!!! Spent 30 minutes with SFI's Arnie Kuhns and he could not come up with a single piece of factual or historical data on S/SS or Comp classes. The criteria SFI based their finding and requiremnt was from circle track and off-road racing vehicles for which they did not have a requirement for a SFI approved flywheel or clutch assembly in their rules. Many of these classes were still running OEM or Chinesium flywheels/clutches. Due to their failures, SFI applied the requirement as a general rule to all motorsports requirements. NHRA has the authority to use the SFI requirements as a "Guideline" or "Suggestion" and extend the requirement as they deem appropriate for S/SS and Comp classes. |
Liked 293 Times in 65 Posts
Just wondering if anyone has heard any new scuttlebutt on this...
Liked 4 Times in 4 Posts
This is stupid!
The shield is a hunk of metal and is not likely to fail just sitting there behind the engine. It should be visually inspected on the OUTSIDE by the NHRA to look for obvious damage, rust and cracks. It should only be inspected off the engine if it has contained a clutch explosion. Tree |
