#12 |
Liked 4 Times in 1 Post
![]() The flexplate should have a counterweight welded to it from the factory. (Not sure why yours wouldn't) From a transbrake perspective, I don't think it would matter what trans you use. The valve bodies are interchangable. I have both a small bellhousing C-4 that is case-filled and a large bellhousing C-4 that is pan filled and both worked fine.
Earle Holt 1055 Stock |
