Old 04-04-2007, 12:32 PM   #11
Chris1529
Liked 70 Times in 29 Posts
Default
I also run the small bellhousing. 157 tooth w/tci flex plate.
Performance Automatic makes the spacer plate that works great. Make sure you get 50 oz balance componets.
I may be wrong, but if you use a case fill trans, you probably have to use the small bellhousing to get a dipstick to fit. I believe most of the large bellhousings came on the pan fill type.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
