Old 10-18-2008, 05:07 PM   #6
Michael Pliska
Default Re: Tubes or Tubeless?
Originally Posted by R&S Motorsports View Post
Always ran Tubeless and never had a problem however I go through a set of tires about every 100 runs sidewalls go away! On a side note your friend with the top dragster was that like a old comp elimanator car with only 13" wide tires?
Not sure if it was originally a comp car, but it was a fairly lightweight, small-block powered mid-7 second car. She had mentioned that it ran a bit slower but obviously hooked better with a bigger set of tires. This was at a bracket finals, and the track prep was pretty decent.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
