Liked 354 Times in 120 Posts
I just saw the 180 hp caddy motor got hit with hp again in ss/ gt now up to 220. Has any other SS motor been hit 40 hp in a just over a year. Not trying to slam anyone but that has to be some kind of record.
Tom Meyer 5240 SS Stock ??? |
Liked 244 Times in 26 Posts
Our 86 C-10 262 cid got 30 hp in a year. Not quite 40, but close. Plus it started in a 20lb/hp class and went to a 18 lb/hp. Index dropped 1.500 seconds and added 400 lbs.
Liked 6 Times in 4 Posts
<<<"Has any other SS motor been hit 40 hp in a just over a year."<<<
Totally aside from WHO runs this combo (that's not my point at all), wouldn't you think that the guy or guys who assign these original horsepower factors would be totally embarrassed to have it demonstrated so graphically, that they have NO IDEA what they're doing? I'd be ashamed...
Bill |
Allowing that combination to be run at 180 HP was rediculous in the first place.
Boob Lang and the rest should be ashamed of themselves. Almost as negligent as the 260 four barrel and 67 Shelby. |
#5 | |
Liked 100 Times in 45 Posts
Now you finally hit a subject that needs to be addressed by the nimrods out in Calif.But nah,they're too busy figuring out how to scam us for more $$ to make up the shortfall coming in the pro ranks.Lets see this thread go 10 plus pages. It seems certain combos are allowed to linger on the edge of HP with no look see.I dont blame the crafty guys who run these combos,it's the laziness of Glendora to do their job.Check et/mph and let the tech guys do what they get paid to do without meddling from the main office. Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA Last edited by Ed Fernandez; 10-17-2008 at 12:10 AM. Reason: Bathroom break |
Liked 477 Times in 117 Posts
stocker version is what made SS guys take notice...
but bob shaw has been good and only got it hit twice... balls though he was dailed -1.37 at indy ![]() caddy rule jack... i cant even get close
Jack McCarthy 3609 STK "the Captain" |
Liked 880 Times in 311 Posts
Just some random thoughts. (probably not worth .02) :~)
I was always been under the assumption the original factor was based on the factory rated HP. Then when someone hammers, or works, the AHFS the factors move. Just because a factory underrates an engine is NOT the fault of you so called "Nimrods" Let's face it.... There are certain combinations that start out factory underrated that respond well to the changes allowed in Stock & Super Stock. For whatever reason, Some have big induction, decent heads & a small cam. Others have the same with a poor set of Ex manifolds. So, when the NHRA allowed changes take place a precieved slug comes alive. A sleeper suddenly wakes up. Who knows why a Caddy had a 180 Hp engine? Could GM have made it that way so all the grey haired old ladies buying those Caddys thought they got good gas mileage. Probably had to do with the original marketing approach of the times. Looks like the system is working when a combo gets hit as hard as the Caddy engine. The hard working guys that have studied the system & used it to their advantage are just reaping the results. Running fast, qualifying high & adding HP to the combo.
Adger Smith (Former SS) |
#8 | |
This particular Olds EFI engine used in the Cadillac, was a dog as an OEM street car. It had many problems related to the ECM and the HP factor from the manufacturer was correct. However, lets take this same engine, built under the current rules were you are allowed an aftermarket ECM and ignition, and other modifications, then you have a performer. So, for smart people like Real Racer, why don't you tell NHRA how they should factor a new combination when they do not have a baseline to start from and all they have is the OEM HP? |
#9 | |
Explain to me how a 40 year old combo still has to shut it down at 1000' if the AHFS should catch up to correct h.p.. Ed F.
Former NHRA #1945 Former IHRA #1945 T/SA |
