#1 | |
Liked 11 Times in 4 Posts
Tim Kish 3032 SS/GS |
#2 | |
Although they may be using a high efficiency S/C, like Evan said, the heat build up is always the limiting factor. I had my learning curve with the Buick Series I and Series II S/C engines and believe me, whenever you increase the boost, a lot of other issues arise. |
#3 | |
The Roush cars are also intercooled. That will also help a little on the heat build up.
Alan Roehrich 212A G/S |
I look forward to seeing these new Mustangs racing. I’m glad that Detroit has recognized NHRA stock racing and has made an attempt to market models that are purpose build. It has been done back in the 60’s so why not now. So what that they are Roush and not built by Ford. With higher fuel economy (CAFÉ) requirements, it’s a way for Ford to not get bothered by the EPA ratings. Ford built the supercharged Cobra in 2003 and 2004 and it is rated at 390 hp. I don’t read any complaints about that car. In fact that car has more potential than the ROUSH since it a 4 valve head. The Roush is a 3 valve head on the same 281 ci block. Last year a lot of people complained that the FI cars were being combined with the carb cars. It seems that everything has worked out fine and the FI cars are not completely dominating all the classes. I don’t think that the Roush will cause too much trouble for the high compression big blocks from the 60’s, especially for a small 281 ci being rated at 435 hp from the start.
Tony
The car has been in the guide for a couple of weeks the weights, HP engine specs all there, take a look before you jump the gun. Trust me I love sixtys muscle cars for that matter all muscle cars and race cars alike. You are just missing the point the OEM,s would like to run current cars and curent power it only make sence. I am aproached at the races all of the time, " is that a 3 valve or a 4 valve a 4.6 or 5.4 and so on" when I explane that is has a 1971 power plant. it sparks confusion for the most part. That was my choice from the begining and have invested quite a bit. so that is how it will stay for now. however I believe that the cars that run stock and super stock not GT with current cars and power will get the attention. and that attention is what the OEM's need. Colin |
To implement boost control as a tech control is actually an unfair regulation on a forced induction engine. As boost is a measure of manifold back pressure you can increase the boost level in the manifold by changing the cam profile - LESS Lift or duration. You have made no changes to the blower/turbo at this point but the boost gauge reading has changed. Relative to performance this may/may not help, higher manifold pressure yields higher airflow velocity but also labors the charger more which creates added heat - its a function of the engine combination. My point is it is not directly indicative of power output. I am working on an application now that runs 8psi boost on the low power variant and 5 psi boost on the high power variant. Exact same supercharger system, drive ratio, etc - the only hardware difference is the cam profile. The low boost version makes 50Hp more.
A regulation on boost level would be no different then to limiting all NA applications to the factory rev limit (Nobody runs higher RPM than the OEM do they?)
Tim Kish 3032 SS/GS Last edited by Tim Kish; 09-12-2008 at 03:56 PM. |
Yes Tim, good points..So if a supercharger or turbo racer wants to run S/SS & the cam, exhaust or other modifications to factory alter boost then the racer will have to deal with it. The racer should still have to run OEM specified boost, not an NHRA arbitrary boost figure, but OEM spec, possibly a +/- boost number. The factory limits boost and the racer should follow those guidelines. If it takes
5K RPM or 8K RPM to see maximum boost so be it. After all, the factory provides all the other numbers we need, right?
Jeff Lee 7494 D/S '70 AMX |
You reckon NHRA's gonna buy a bunch of telltale boost gauges and then loan them out for free?
#10 | |
If they did limit boost than it sounds like your goal would be to find the best cam and boost combo to make the car run fast with the limitations set. Why would this not be a great way of limiting these cars adn still being a competitive combo in the class? Boost does not necesarily have to be limited to factory, so there could still be room for performance gains. SSDiv6, Is there a thread on classracer that you don't pop into and know EVERYTHING about. Or talk like it. |
