Liked 3 Times in 2 Posts
You miss the point.
Whether it be the first crack at a combo or not, the factor needs to be correct before the engine is run. The source of the heads, aftermarket or OEM doesn't matter. The correct HP can be accurately calculated and then a factor assigned. FJ |
#2 | |
Congrats to Frank Grossi for finding the combo and having the courage to run it. Also congrats to all the guys at Eaton for making the power and Phil Mandella for the killer car and chassis set up.
Lynn A McCarty 3470 SS Last edited by Lynn A McCarty; 09-06-2008 at 06:54 PM. |
My point is the system as it is, is antiquated.
It allows a combination to run at an unreasonable HP factor until (if) the factoring system catches up. Yes, I'll credit someone to choose something new, but the factor needs to be reasonable and with today's technology, that is not difficult to achieve. In the meantime, it makes the tried and true (and in many cases overfactored) combinations un-competitive. FJ |
The real problem, as I see it, is that there are some combos that are classified wrong. They will run with an enormous amount of weight and still run 1.3 or more under. The tech people should be aware of somebody running real fast then being way over at the scales. It is sandbagging to save their bogus combo. If they get hit, they will just remove some weight and go for it again. The combo can be milked for years like this.
Running overweight is an additional problem of engines being under-factored.
It's always been difficult to understand why NHRA tech doesn't take this into consideration when re-factoring a combo. After all, they record weights every time the car goes over the scales, so why isn't this included in the re-factoring? This is another reason why engine combinations, especially new ones should be properly appraised for the correct HP factor before being approved for use. The current factors for a couple of these combos are out by approximately 30hp! FJ |
Liked 11 Times in 4 Posts
ALL i know is that is one fast car.
It is definitely FAST.
Car#-Driver(Opp'nt)-RT-----ET-- Speed-----Car#-Driver(Opp'nt)-RT-----ET-- Speed 7056 Frank Grossi 51 Gary Stinnett E5 ****WINNER**** 0.095 9.073 145.80 0.033 9.232 147.73 GT/AA Dial: 10.40 (+/-): -1.327 GT/AA Dial: 10.40 (+/-): -1.168
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
