Old 07-17-2008, 10:09 AM   #1
BIZMANRACING
BIZMANRACING's Avatar
Default Re: Rear tire air pressure
thanks bobby
but, thats not what i mean by big tire. i ran those pounds also when i had the smaller tire.
no my question was for door slammers weighting 3000 lbs with 32X14.0X15 i got 8lbs. some folks say i should have less, but the car weights so much.
your thoughts?????????
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
Old 07-17-2008, 11:09 AM   #2
bobby
bobby's Avatar
OH, they are big for me, LOL. My brother runs something like a 14x32 and runs 9, I think. I usually don't check his tires. His wife does that for him. He also runs a footbrake car and M/T tires.
bobby is offline   Reply With Quote
Old 07-17-2008, 11:11 AM   #3
Dave Goob Cook
Dave Goob Cook's Avatar
You are close, given the variances of tire gauges at low pressures, you could run anywhere from 6 1/2 to 8 1/2 and be "correct"....it also matters whether it is a stiff sidewall, the front/rear weight balance, and how much it gets up on the rear tires for the launch.
If you aren't wadding the tires on the launch, they leave a full footprint, and wear even across the tread section, you have it right.
Sounds like you are having a hot track / tire compound issue to me.
I ease up on the burnouts when the track is hot, as well as running a "medium-hard" (Goodyear D-4A) compound for that purpose.
When the track temps exceed 110-120 degrees, I do a dragster type burnout and roll to the line.
Dave Goob Cook is offline   Reply With Quote
Old 07-17-2008, 03:27 PM   #4
BIZMANRACING
hi dave
no i don't have the corage to do a dragters type buntout. with no line lock at all, i'm not sure it would clean off the tires enough and "hook" on the hit. sometimes i'll do a shorter burn out and roll forward. its just those 60 fts not being consistant enough for my liking. just was wondering if pressure helped one way or the other.
as for the foot print yea i know about that one to. seems smooth right across, its about time to rotate them i got about 20 runs on them now, time to flip them over
S/ST 1739
Carlos Mendes
Old 07-21-2008, 12:59 PM   #5
Joe Sprint Bros
Don't forget to measure the rollout while you're rotating them.Joe.
Joe Sprint Bros is offline   Reply With Quote
Old 07-21-2008, 02:18 PM   #6
BIZMANRACING
Why ?????
S/ST 1739
Carlos Mendes
Old 07-22-2008, 12:12 AM   #7
mrolds
mrolds's Avatar
I ran 8-10.5 on my 14.5 x 32's on my 3200# 65 442 clone running as quick as 9.90.
If you think you're 60's are inconsistent , try radial slicks! On a poorly prepped track my 30 x10.5 radials will 60' Either 1.50 or 1.80 ,& not much in between. Now on a decent track they'll be 1.50 all day!
Jeff Smith S/ST- Pro/ET 5102
Creating the streetable S/ST Olds
mrolds is offline   Reply With Quote
Old 07-22-2008, 11:15 AM   #8
SlickVic
SlickVic's Avatar
Carlos, the tires can be a differen't circumfrence even though they are the same size so measuring the rollout of each tire will tell ou this. Also in a 2500 lb car and 2700 lb car i run 6.5 to 7.0 In a 3100lbs car We run 7.5. You need to run as high as pressure as you can w/o spinning or being inconsistent. So i would start out around 7.5 and go up from there. And it does depend on the gauge, but i use two of the 80$ jegs gauges and both of them read exactly the same.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
