Old 07-15-2008, 09:10 PM   #21
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: IHRA FWD Weight Breaks
Oops, that would have been 2005!
You're losing it old man.See ya at the Toyo's.
Ed
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-15-2008, 09:38 PM   #22
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Ed
They will forever be the Keystones.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 07-15-2008, 10:18 PM   #23
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
I think there's a couple other little killer combos out there that I may keep under my hat for a little bit... Billy, do you still have the car I borrowed to drive back and forth between PA and Ohio? I think we figured that one to have a great deal of potential. I know another combo that will run the index completely untouched, which I think would have a huge amount of potential just by dropping the exhaust and putting a set of 20" M/T's on it...
Old 07-15-2008, 10:58 PM   #24
Dennis P Chapman
Liked 53 Times in 25 Posts
Come on Mike give us a hint.
Dennis P Chapman 1904 STK
Dennis P Chapman is online now   Reply With Quote
Old 07-16-2008, 06:25 AM   #25
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Have you ever seen Billy's headers? I wouldn't foresee a problem LOL. If I come across one for under $500 I'll throw Dad's back up 350 in it and see. The torque converters are the same correct?
Daran Summerton is offline   Reply With Quote
Old 07-16-2008, 09:23 PM   #26
Michael Beard
Awright.... too fun! Check out an '05 Cobalt. I've seen them run 16.40's absolutely bone stock. I believe it runs FF/SA (16.30 index) in IHRA. Ran my fiance's at Rockingham once (albeit 1/8th mile), and went some rounds. Not a bad piece. They had the scales on, and I think it was something like 300# heavy! Tires (gear), exhaust off (weight *and* power), airbox, fuel, etc... stands to pick up a ton. I think it's a pretty good sleeper combination.
Old 07-16-2008, 10:20 PM   #27
Dennis P Chapman
Mike
I drive and 07 cobalt runs pretty good may have to take it atco.
Old 07-16-2008, 11:36 PM   #28
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Hi Mark, incase you've forgotten, 1985 Pontiac Sunbird Turbo. Original engine, trans, converter AND final drive ratio went 14.03 on 14.95 B/FS index in 1985. I haven't raced the car since. The only things that I changed were a fresh head gasket, a fresh turbo (the right one) and 20 X 8 M/Ts. In fact, it DID win class at Indy on a solo run.
Hi Billy. Actually it was 2004 (50th) Indy. ET was 14.22, for those keeping score at home. It did run 14.11 on the brakes at the Dutch that year. How are things up on the "ranch"?
