Old 07-05-2008, 04:46 PM   #1
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Default To use a solid rear trans mount ?
Some advice would be appreciated. My car will be using an alum front plate, .090 steel midplate and I have read in the TCI catalogue "never use a solid trans mount". Engine is BB Chev and trans is TH 400.
Chassis is round tube and car has certified (to 8.50) cage .
Old 07-05-2008, 07:53 PM   #2
jmarkaudio
Default Re: To use a solid rear trans mount ?
That is good advice, NEVER. A sure way to break a case.
jmarkaudio is offline   Reply With Quote
Old 07-06-2008, 09:05 AM   #3
1968chevelle
I couldnt agree more....
1968chevelle is offline   Reply With Quote
Old 07-06-2008, 01:39 PM   #4
Tim H
Tim H's Avatar
Ok , well I will stay away from the solid steel Moroso mount for sure. Thanks guys.
Old 07-10-2008, 01:26 PM   #5
bobby
bobby's Avatar
that's funny you started this thread. When we got my wifes 71 camaro bracket car it had one. took it off and just put on a stock rubber one. Was trying to sell the solid one, got tired of kicking it around the garage and threw it away on sunday.
bobby is offline   Reply With Quote
Old 07-10-2008, 02:23 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Never had a problem with solid mounted trans. Solid mounted engine and solid mounted trans in my car. No issues.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 07-10-2008, 09:22 PM   #7
dak
Motor plate. thin alum mid plate and a solid trans mount. never had a problem. In my car the cross member is non removable. You could probably pick the car up from the cross member as it is set through the tubes and welded inside and outside. not just butted up against and welded up
good luck
dak is offline   Reply With Quote
Old 08-01-2008, 11:44 PM   #8
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
I have always heard to never mount tail shaft solid...............but I have to tell you, I have no idea why. I would think that if everything is mounted as solid as a rock, but then you have the tail shaft just bouncing around, that would cause breakage. I am sure chassis flex has alot to do with it, anyway, i have had everything solid mounted on my car forever with no problem.
H.A.A.C. Racing is offline   Reply With Quote
Old 10-02-2008, 10:47 AM   #9
Raceready
My car weighs 3330 lbs,turbo 400,pontiac engine front plate, mid plate,crossmember is round tube bolt in,tailshaft is bolted straight to the crossmember.2X3 Chassis 4 link a arm car.No issues in 8 years running 6.70 1/8 mile 10.70 1/4 mile 60 ft 1.38.If the car don't twist shouldn't have a problem.
Raceready is offline   Reply With Quote
Old 11-08-2008, 02:55 AM   #10
Mitch Perkins
Mitch Perkins's Avatar
We use the urethane mounts on every car built in the shop. With 1/4" front and mid-plates, or with the .090" mid-plates ( which I consider obsolete, 1/4" mid-plate helps to transfer torque to the chassis and the thin steel plates distort). Never had issues with breakage, However, the ones built with solid mounts at the least cracked the mounting bosses on the case even if the housing survived.
Mitch Perkins Perk-Bilt Race Cars
DragCoverage.com Staff Photographer
Mitch Perkins is offline   Reply With Quote
