Old 08-29-2025, 07:55 PM   #1
larrylomascolo
Liked 77 Times in 31 Posts
Default Re: Tear Down B/S ... must read
Dan had this carb with the holes at a previous tear down and it was no issue carb passed.so now it does not pass tech..This is so not right .not a power gain .double standard this should be protested . . He and car were dialed in.this is so sad..probably wont see the Williams Bros. Stockers no more.... . SAD
Old 08-29-2025, 08:33 PM   #2
There is no performance advantage. It's a simple idle tuning modification.
Consider what they're actually letting pass, the rule/ruling is absurd.
Old 08-29-2025, 08:34 PM   #3
A l a n, now we have no holes and with holes. Were they approved or not? Makes a big difference here the way I see it.
Old 08-29-2025, 08:43 PM   #4
Yes, the Quick Fuel 780 as approved, accepted, and delivered, came with holes in all four throttle plates, and we were told to drive lead plugs into the openings to cover the secondary idle mixture adjustment screws.
Old 08-30-2025, 10:47 AM   #5
L.Fite
Liked 498 Times in 244 Posts
So...
Were the idle screws removed as required?
If so they probably should have been given the option of fix the holes...
A 15 minute fix with a little solder...
Was that after all qualifying was over?
Were they DQ'd from class?
Or the hole event?
Kind of a dumb rule in my opinion...
Don't even see the secondary idle screws as a performance advantage...
Especially when the rules state "any internal modification allowed"...
Or did I misread that?
Can someone explain the advantage, I'm always willing to learn something new...
L.Fite is offline   Reply With Quote
Old 08-30-2025, 01:02 PM   #6
1347
1347's Avatar
Liked 1,027 Times in 282 Posts
Originally Posted by L.Fite View Post
So...
Or the hole event?
Qualifying and class were over. There was no chance to fix it and run again. There are alot of things that are not a performance advantage that are illegal in class racing. Its not techs job to decide what they will let go thru in the barn because the rule doesnt help performance.
Someone was told.they couldnt run without fog lights in their bumper cover. Luckily they had them and it was taken care of.before Qualifying and class was all done.
I heard a tech official say " we bounced ....... for the same modification 2 years ago, we cant let it go today"
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 08-30-2025, 03:35 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
I just took a few minutes and read the carburetor section of the rule book for Stock Eliminator. The rule clearly states that you can drill the primary throttle plates. It does not say you can drill the secondary throttle plates. It does state that no other modifications can be done. If indeed the secondary throttle plates were drilled the carb is illegal by the rule book and the interpretation of the rule is correct by the tech department. If it passed before it doesn?t supersede the rule as printed at this time. I have been tossed in the past for an insignificant detail like this. All you can do it?s take the penalty and move on. Fix the issue. Have the repair inspected by tech before the next race and run even faster.
Mike Pearson 2485 SS
Old 08-30-2025, 08:14 PM   #8
L.Fite
Thanks, wasn't sure when it all occurred...
Old 08-30-2025, 04:32 PM   #9
pmrphil
Liked 393 Times in 153 Posts
So...
Or the hole event?
NOT the mixture screws - the issue was holes drilled in the secondary throttle blades. For which there is NO performance added. ZERO. The rule book says no, but the approved Quick Fuel carbs (SSR 780) came with holes in all 4 blades.
The idle mixture screw heads had to be "covered" to make them "legal".
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 08-30-2025, 04:54 PM   #10
SS3860
Liked 176 Times in 59 Posts
The Quick Fuel carbs did not come with the secondary plates drilled. The idle mixture screws were cut down so you could adjust them and then use Grey silicone to cover them.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
