#1171 |
Liked 10,804 Times in 2,245 Posts
It was a new converter that may have had the tolerance stack line up the wrong way. It happens sometimes.
Like a big crank, to the plus side of the tolerance, a housing bore to the tight side of tolerance and a bearing shell that is on the small side resulting in an unacceptable clearance problem. I am trying to correct a few perceived future problems. Last edited by Larry Hill; 07-28-2025 at 08:36 AM. |
#1172 |
Yesterday after supper the house A/C died. We slept in a house that was 83 to 84 degrees. We just got it running. The start capacitor died. Installed a new one and has lowered the temperature one degree in 90 minutes. Heat index is close to 115*
#1173 |
Liked 333 Times in 180 Posts
try to Stay cool and be safe--- don't do anything stupid--- drink lots of water----if you sweat a lot take salt tablets too---FED 387
#1174 |
Back after it today. Good start to the day I found my scale notes. When I started we weighed the car with me in it with all my stuff on and recorded all the numbers at each wheel. I then started adding weights in the seat and floor to mimic me in the seat and duplicate the scale weights. That comes a little later we still have ton of wires to connect.
#1175 |
Connecting the wires is easy, it is supporting them and keeping them off of the headers is the challenging part. We are getting there making brackets and such.
#1176 |
My hands and lower arms looks like I have been fighting with cats and losing. Hope to be at BG next week to race and test.
#1177 |
Liked 51 Times in 25 Posts
Are you still running FS or did you convert Dumbo to regular stock class?
#1178 |
FS/D I am way to deep in to it to change now but I have the 6.1 DP that came with the car and a replacement 09 street engine and a 15 6.4 street engine just in case.
I had to get more tie raps and band aids. I am about to believe that no matter how many times you route and re route sensor wires it is never what you are satisfied with. I am hopeful that I can get the car on the scales this weekend. |
#1179 |
Liked 2,741 Times in 967 Posts
Dumbo is obviously not a joy to work on.
#1180 |
Part of the problem is me and my size.
