Old 07-16-2025, 06:20 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 226 Times in 74 Posts
Default Flush
What is the best method for flushing the cooling system at home? Trans builder said to flush the system after finding debris in my trans.
J.T. Rose & Associates U/SA T/SA 302R
Rose Racing is offline   Reply With Quote
Old 07-16-2025, 06:50 PM   #2
Liked 1,784 Times in 407 Posts
Default Re: Flush
Most parts stores carry "Cooler Flush", usually, two cans will do the trick to flush a transmission cooler.
Old 07-16-2025, 10:52 PM   #3
CMcAllister
Liked 914 Times in 257 Posts
Default Re: Flush
Kooler Kleen
Old Yesterday, 08:25 AM   #4
JP1738
JP1738's Avatar
Liked 1,167 Times in 330 Posts
Default Re: Flush
I don't know if this is good or bad, but historically, I've just sprayed a bunch of brake clean through the lines and blown them out with an air hose. Makes a mess but gets the job done.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old Yesterday, 12:49 PM   #5
dragracerray
dragracerray's Avatar
Liked 207 Times in 88 Posts
Default Re: Flush
J.T.,
Trans guy wants you to flush the transmission fluid cooler in the radiator or wants you to flush the antifreeze? If you have debris in the transmission fluid cooler side of the radiator some times it is best to install a new radiator. Ray
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old Yesterday, 02:03 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,915 Times in 574 Posts
Default Re: Flush
I dont know anyone running a cooler on a race car. I never have.
Mike Pearson 2485 SS
Old Yesterday, 03:29 PM   #7
pmrphil
Liked 346 Times in 150 Posts
Default Re: Flush
Originally Posted by dragracerray View Post
J.T.,
Radiator cooling lines are just that lines, NO fins.
A plate and fin type cooler should be replaced, tube style can be flushed.
Either one, WAY cheaper than another trans rebuild because of recirculated trash.
Phil Molski
PMR Performance
S/C 1623
