Liked 1,784 Times in 407 Posts
Powermaster 100 amp 1 wire. They;re even available adjustable for voltage output.
Alan Roehrich 212A G/S |
Liked 44 Times in 20 Posts
House of Payne makes really nice 12v @ 100 amp alternators in a Super Mini and an Ultra Mini.
https://whitehouseperformanceparts.c...2v-alternator/ |
Liked 9 Times in 6 Posts
napa full size Delco 1 wire 60 amp ? SW something, only about $60
Liked 380 Times in 147 Posts
Checking them out now. I'll get a 100+ amp one just so I won't have to worry between rounds!
Thanks, for the info guys!
Jim Miller 103 U/SA |
Liked 309 Times in 118 Posts
I don't run an MSD in my race car which I guess is a big draw in amperage but I run a stock 1963 30 amp alternator in my race car with a small pulley on the damper and never have to charge between rounds and I run the electric water pump and fan between rounds to cool sometimes.
Liked 1,102 Times in 301 Posts
Like Paul, I have found the factory equipment alternator more than adequate. On my 85 Mustang Stocker, as well as my 78 Fairmont bracket car, I used the factory alternator and external voltage regulator, Ford offered them in several different output ratings, I think the alternator that has been in my Fairmont for almost 40 years, is less than 50 amps. That said, I am also using a full sized conventional battery, with 500-600 CCA. My cars have much of the typical drag car stuff, like an electric water pump, electric fan, electric fuel pump (s), and a MSD ignition, although I run 6 series boxes, I believe the 7 series boxes take a fair bit more current to operate. Over the years, I have found that as long as I had the battery fully charged before the race weekend, with the full size battery and alternator, I can usually go thru a 2 or 3 day race weekend without having to fire up the generator and charging the battery between rounds. About the only time that I charge the battery, is if I am in a "hot lap" situation during later rounds, especially on a hot day, so that I have to run the fan and water pump a lot. Obviously, if your alternator is non functional, that wouldn`t work.
Liked 133 Times in 76 Posts
How much amperage do you think you need? What gauge wire are you running from the alternator that can carry the amperage?
