Liked 115 Times in 35 Posts
What are you guys using for a pilot bearing or bushing?
I have been using a ball bearing in a bushing made to fit in the back of the crankshaft. This is the larger hole where the convertor hub would fit. Problem is getting one made for each specific crank and fit needs to be about perfect. Also can have clearance problems to the splines on the input. I tried a bushing from speedway once that has a shoulder for extra height with a motor plate. It spun loose after very few runs. I have a torrington type bearing here from moroso goes in stock pilot hole. Anyone use these? Believe this is used in some oem applications. |
#2 | |
Liked 1,428 Times in 296 Posts
The modern clutches we all use put more strain on the pilot bearings so anything other than a good strong roller bearing is going to get wobbled out and can cause issues. Thst is ok as long as you keep an eye on it and are prepared to change them as needed.
James Schaechter 3163 STK |
Liked 5,109 Times in 1,947 Posts
I have used roller bearing, in place of a bushing, but let's just say they are unforgiving.
I had to indicate the bell housing and re-balance all the clutch components...then it was fine.
Liked 29 Times in 5 Posts
Lakewood 15975. For chevy engine and the bigger ford pilot size. Have run these for years.
SS/AM 2917 |
Yes you just answered my next question. Upgrade to the Ford pilot size.
Thanks for all replies. |
Liked 172 Times in 46 Posts
Call G Force have them in two motors with different crank manufactures and I have had no problems. I used to get them from Jerico but these fit much better.
Dirk Olson 5036 STK |
Liked 293 Times in 65 Posts
I've been using the GM 12557583 that registers in the larger hole in the crank where a torque converter fits.
Available on Summit for $13.99. Haven't had to pound out a pilot with bread ever since! Haha |
Liked 1,102 Times in 301 Posts
On my 427/428 FE Fords, I use a sealed ball bearing, supposedly the original application was a GM alternator. only issue is an extra .001 or 2 would hold it in better, sometimes it slides out while removing the transmission.
On my SB Fords, I use a factory needle bearing pilot for a 5.0L FOX Mustang, and replace them every year, as they tend to wear. Many years ago, when I bought my first Jerico, and McLeod "Soft Lok" sintered iron disc clutch, I used a factory bronze bushing, but the iron dust from the disc ate the bronze up really quickly.
#9 | |
Ordered one and will see how it fits. Measuring this crank looks like it should work. Aftermarket crank. If all goes back together will test it somewhat locally, Julesberg, and hope to make the midwest and divisional races at Earlville. |
