Liked 5 Times in 3 Posts
What's the differance between the 352 & 390 ? Bore & stroke?
The 352 is a 4in bore with a 3.50 stroke,where the 390 is a 4.05 bore with a 3.78 stroke
Thanks!
Liked 1,604 Times in 583 Posts
...and 428 racers like the 390 block for strength...
HUH!??! To make a 390 block standard 428 bore size, you would have to bore it .080" over. I find it tough enough to get 428 blocks with thick enough cyl. walls to go .030", let alone a 390 which has thinner walls t5o start with. On my low 10 second 428 bracket car, I split 2 cylinders last year alone.
Liked 14 Times in 11 Posts
You might want to contact Curtis Couter in Las Vegas, he seems to
have found a way to make 390 into 428 motors live in his D/S Cyclone.
Phil Saran Parker, Colorado |
Liked 333 Times in 180 Posts
My sources tell me that you want a TRUCK block!!!! Even tho the dimensions are the same truck blocks were a unique casting much more heavy duty than a passanger car block------No way of knowing either way what is true but it makes sense to me get the truck block!!!! --------------Comp 387
My sources tell me to look at website ---428cobrajet.org----------- look for block ID--it gives you a fairly indepth description of what you neecd to know/look for too---comp 387
thanks Fed 387
