Old 05-16-2025, 08:28 PM   #1
Stock726
Liked 13 Times in 9 Posts
Default Tossed on a Single?
I can't recall ever seeing this one before. I know you have to stage the car to win a single, but I would think a warning would suffice. Was this an oops moment or something else? Anyone in Joliet with the real untold story?
Stock726 is offline   Reply With Quote
Old 05-16-2025, 11:19 PM   #2
Liked 1,784 Times in 407 Posts
Default Re: Tossed on a Single?
It says "rolled past', not "crossed under power".
Wow.
Old 05-17-2025, 12:39 AM   #3
FED 387
Liked 330 Times in 178 Posts
I believe that the only cars that can "burn out" past or go past the starting line are any dragsters--and various other classes of cars DEFINATELY NOT Stock Class or Super Stock Class cars---IF you go past the starting line on a burnout you are eligible to be tossed/disqualified---looks like that's what happened here-- FED 387
Old 05-17-2025, 08:05 AM   #4
At one time, the rule read clearly, "cannot cross the starting line UNDER POWER".
Old 05-17-2025, 08:51 AM   #5
Bandit 1
Liked 24 Times in 16 Posts
Throttle hung open on the burnout. Could have been a bad situation for all involved, thankfully it was not.
Bandit 1 is offline   Reply With Quote
Old 05-17-2025, 10:46 AM   #6
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 218 Times in 94 Posts
Back in the 90s I saw a guy leave before the tree was activated on a single run at a national event, and he was not allowed to appear in the next round.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 05-17-2025, 11:28 AM   #7
Jeff Niceswanger
Liked 1,019 Times in 367 Posts
One year in Columbus Joey Wilkes had a heads up the following round... and prepped his car for it on the current bye run. Made a mistake, was 5 or 10 light at scales. Never forget his pit guy (Mike Means) yelling at the TOP of his lungs as Joey tried in vein to explain. Mike is "YOU CAN'T GET THROWED OUT! ITS A BYE RUN! LOL...
Jeff Niceswanger 3740 SS
