Old 05-02-2025, 06:40 PM   #10
SS3860
Liked 162 Times in 55 Posts
Default Re: Consistency
Originally Posted by Barso1514 View Post
So I have pan heaters for trans and motor. I have a race air cloud with their race base software. I definitely do not cheap out on things. I try to buy the best of the best as long as I can afford it. I just put a grid in it to help slow it down because at minimum I?d do more harm then good due to the old ahfs
I used to bracket race with a grid. Found car was more consistent running with the proper timing and at peak power than pulling timing and slowing car down. Now if you're using the ARC module dot to dot that's a different story.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
