Old 04-27-2025, 11:59 PM   #1
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Default Re: And you thought air/ electrical shifters in stockers was
https://classracer.com/classforum/pi...pictureid=1908 who got the win? front dam/spoiler on camaro plus a little brake waalaa, clearly my wheel is on stripe
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
Old 04-28-2025, 12:14 AM   #2
Cglrcng
Cglrcng's Avatar
Liked 333 Times in 185 Posts
Who got the win on the slip Frank?
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is online now   Reply With Quote
Old 04-28-2025, 12:41 AM   #3
Cglrcng
Cglrcng's Avatar
The problem was noted earlier, we do not race wheel to wheel (all different circumference sizes of wheels are used), we race beam to beam spaced 1,320' apart start beam is 3" off the ground, finish line beam is 6" off the ground. The multiple categories and
classes and many, many types of cars is
the reason. And on that day in this time
The published ruleset and NHRA
decisions stand. They change the rule, a wrench, 2 nuts and bolts and a cable tether unscrewed and the blade is removed. No crying here personally but a lot of cars will need to be otherwise unaltered in S/SS. Beyond a few...lots of em.
It is a fake advantage (meaning there is zero advantage), that has outlived its
usefulness. A crutch I certainly do not need to walk or run, and is time to go back to making us both guess which part of my car will break that beam 6" high...bumper, air dam spoiler 1, air dam deflector 2, or tire. (All in Stock locations as mfg.d and 0", 4", 14", & 28" apart under my cars front end), depending on my last 1300' plus move(s). Right now with it there I don't have any affect no matter what I choose to do.
Sometimes you get what you ask for.
Old 04-29-2025, 10:59 AM   #4
Frank Bialas
The camaro,I couldn't believe it , I knew it was close but I also knew that I was out front.What stinks is I was told to tuck my wire in that was for a parking lamp in my bumper!?!?
Old 05-01-2025, 05:28 PM   #5
Cglrcng
Cglrcng's Avatar
I knew that by the finish line photo, but wanted to confirm it by asking. We race from a dead even start by front tires, and the finish is determined by a beam much higher and a million variations of front ends at the stripe, and a whole host of last move variables that are determined by both drivers due to that beam height difference.
His car in the photo is way out in front of your tires. And he already broke the stripe beam. Ty for confirming the photo view.
