Old 03-07-2025, 11:10 AM   #41
Casey Miles
Liked 488 Times in 90 Posts
Default Re: Air shifters in stock?
Maybe Nhra should rename Stock eliminator to "Bracket Stock Eliminator" ?
Old 03-07-2025, 11:21 AM   #42
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
So the “fun” is gone when you don’t push/pull your shifter twice?
If that is true, the easy solution is don’t use an air shifter but I’ll bet most of your competitors will.
Old 03-07-2025, 07:00 PM   #43
L.Fite
Liked 494 Times in 241 Posts
Originally Posted by Chris1529 View Post
I am thinking that if you can't at least manually shift an automatic transmission, maybe driving a racecar is not for you.
Meanwhile...
Back at the ranch I'm trying to figure out how to airshift a G-Force...
Hmmm...
L.Fite is offline   Reply With Quote
Old 03-07-2025, 07:21 PM   #44
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Pro Stock racers were using air shifted transmissions years ago.
It was knocked out by NHRA
Some manual trans comp cars use air shifted 4 and 5 speeds I believe
I personally don't have a problem shifting my car manually but as I said.....
racing 1/8th mile makes it more of a dis-advantage.
If you drive a slow car that does not wheel stand......it's a non issue...
If you choose to race a stick shift car and it's fast, you're already at a big disadvantage....your choice....
Stock eliminator IS BRACKET STOCK.....Sure there are heads up races but it's primarily a dial in with a breakout form of racing.....been that way for years and years....
If you want to win, you use whatever equipment that can help and is allowed.
If you can afford a killer fast driveline so you are the fastest car in the class, it's the same thing.....You bought what can win for you...
Rich Biebel
S/C 1479
Stock 147R
Old 03-07-2025, 08:36 PM   #45
1320racer
1320racer's Avatar
EXACTLY!
Rich Biebel…KNOWS!
Old 03-07-2025, 10:42 PM   #46
L.Fite
LOL...
Old 03-08-2025, 09:30 AM   #47
GUMP
Liked 2,336 Times in 549 Posts
Originally Posted by 1320racer View Post
So the ?fun? is gone when you don?t push/pull your shifter twice?
If that is true, the easy solution is don?t use an air shifter but I?ll bet most of your competitors will.
No. That is not the answer. This constant dumbing down of Stock Eliminator is, in my opinion, wrecking the class.
The easy solution is to leave the rules alone and quit catering to the weenies of the world. If they need automatic shifting and can't figure it out within the current rules, THEY should do something else....
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
Old 03-08-2025, 09:37 AM   #48
MoJo Risen
Liked 125 Times in 47 Posts
Ah, yes. They are doing something else and they tell us it's the future of our sport remember?
I can see the future already, tons and tons of Junior dragsters with no gear shifting.. Better get yourself one before you're left out.
MoJo Risen is offline   Reply With Quote
Old 03-08-2025, 09:56 AM   #49
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Originally Posted by L.Fite View Post
Sneaking up on roller cams!...
Say it ain't so
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-08-2025, 10:00 AM   #50
1320racer
1320racer's Avatar
No. That is not the answer. This constant dumbing down of Stock Eliminator is, in my opinion, wrecking the class..
As you stated, your opinion. Meanwhile, I’ve spoken to numerous stock eliminator racers whose opinion is changes such as this are welcome and more is needed to save the class. Like it or not. Stock eliminator is bracket stock as Rich has stated.
