Old 03-04-2025, 04:39 PM   #11
littlemanjoe
Liked 75 Times in 28 Posts
Default Re: Air shifters in stock?
Originally Posted by John Dinkel View Post
I'm going to continue pushing the buttons in my Max Wedge. Air shifter sounds too confusing.
John, that's what separates the boys from the men..... Pushing buttons ain't easy.
littlemanjoe is offline   Reply With Quote
Old 03-04-2025, 04:44 PM   #12
Liked 5,119 Times in 1,950 Posts
Originally Posted by littlemanjoe View Post
It looks like they will allow RPM shifting devices in stock for 2026.
Why do they want us to be like Super Stock?
I don't know where you're getting this from, but might as well.They have been allowing solenoid shifting inside the trans on year / models that never had electronics internally to begin with . Been going on for years.
Also, you've got Stocker guys putting up Y/T videos of them never using the clutch after the launch!
I'm told that a true clutchless trans is a better deal, but much more expensive.
So there ya go...More goodies for the entry level class LOL
Old 03-04-2025, 05:14 PM   #13
Liked 2,050 Times in 398 Posts
OK?..and you can still use E shift ?.Your point ????
Don't blame everything on the existence of the COPO as your car can use them also .
Old 03-04-2025, 06:48 PM   #14
Paul Precht
Paul Precht's Avatar
Liked 319 Times in 119 Posts
Same here, I've been pushing the same buttons in my Sport Fury since 71, it's so simple and perfect although I hit second a bit too late on occasion.
Old 03-04-2025, 07:56 PM   #15
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
Originally Posted by GUMP View Post
Wasn't me!
Likely came from the other coast…the slope keeps getting more slippery by the moment.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-04-2025, 07:57 PM   #16
jmantle
Liked 172 Times in 81 Posts
Originally Posted by 64 savoy View Post
And no clutch shifted 4-speeds.
We ran no clutch back in the 60's, broke a lot of parts
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 03-04-2025, 08:33 PM   #17
Jared Jordan
Liked 534 Times in 118 Posts
Send a message via AIM to Jared Jordan
Likely came from the other coast?the slope keeps getting more slippery by the moment.
Why does the West Coast always get blamed for the rule changes? Or lack of enforcement? We, collectively, seem to do pretty well at Indy when needed.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 03-04-2025, 08:56 PM   #18
mnmaxwedge
Liked 172 Times in 53 Posts
2025 rulebook says that pneumatic, rpm controlled shifters are allowed in stock after Jan 1, 2026
mnmaxwedge is offline   Reply With Quote
Old 03-04-2025, 08:59 PM   #19
Liked 1,797 Times in 410 Posts
Like Super Stock?
They were in Super (0.90) classes and bracket cars before they were in Super Stock.
I doubt Super Stock is where they're looking at taking you.....
Old 03-04-2025, 09:02 PM   #20
littlemanjoe
SECTION 11A: STOCK CARS, DRIVETRAIN: 2, TRANSMISSION, AUTOMATIC
(Page 7) (02/25/2025)
Any model transmission, same make as car, with a maximum of three forward speeds
(unless OEM equipped with more than three forward speeds). O.D. gear not required,
reverse permitted. Transmission case must be OEM or aftermarket OEM replica from a
standard, automotive application as found in the Official NHRA Stock Car Classification
Guide. Aftermarket case must meet SFI Spec. 4.1. NHRA-accepted adapter plates
permitted. Modifications to shifting patterns are permitted, provided full shift pattern is
retained. Full shift pattern must include park and reverse. Any gear change must occur
as a result of an internal function of the transmission or from direct action by the driver.
Lockup converter permitted if OEM-equipped with lockup converter and OEM
transmission is used. Otherwise, lockup converters prohibited. Electronic transmission
controls for the electric shifting of automatic transmissions to shift via internal function of
the valve body only permitted in computer-controlled vehicles only; may shift by RPM or
time only, wires for line lock, wheel speed, driveshaft speed or GPS signal prohibited.
Otherwise, any gear change must occur as a result of an internal function of the
transmission or from direct action by the driver. Pneumatic, electric, etc. controls in all
noncomputer-controlled electronic fuel-injected vehicles prohibited. The use of air
assisted or electric shifter is prohibited in all Stock applications.
Beginning January 1,
2026, RPM-activated pneumatic, electric shifters permitted. Deepened stock or
aftermarket transmission oil pans permitted. Drilling of transmission case or rear of
engine block to adapt incompatible units prohibited. Functional neutral safety switch
mandatory. Transmission brake prohibited. Tailshaft modifications for bushing
replacement, or NHRA-accepted aftermarket tailshaft, permitted. Any car running
quicker than 10.99 must be equipped with a transmission shield meeting SFI Spec 4.1
