Liked 759 Times in 379 Posts
Hoosier is the #1 brand of racing slick in all of drag racing, run by more racers than all otters combined, They also hold air and are fast. Goodyear and M/T which is owned by Goodyear are used by some of the biggest names too. Keep in mind also, that all three have deals with many racers. Phoenix is another tire run by some racers, mostly in super stock.
That all said. you eluded that you plan to compete in S/ST and IMO your choice of tire should not be your concern, rather your choice of car and combo. Last edited by 1320racer; 02-04-2025 at 09:37 AM. |
Liked 648 Times in 193 Posts
When we ran TS we tried MT, Goodyear & Hoosier. Hoosier Hands down gave us our best times and also best value for our money. And we never had a Hoosier leak down! Hoosier for the win!
Agree
Liked 357 Times in 119 Posts
I've run several sets of both brands of typical stocker tires. 30x9 radials. Cars both ran great on either brand. The difference is MT's had cords showing at 75ish runs. Hoosiers I easily get 100+ runs out of a set. I've spoken to a couple MT reps and they say that's normal and were unwilling to do anything for me on a new set.
Liked 2,486 Times in 697 Posts
Any of the Racing Slicks you mentioned will be fine
on a car with 1.5 @ 60 and a glide unless there is a major chassis issue.
Liked 1,220 Times in 342 Posts
4400 pounds tho. If it weighed 2800 it'd be more like a 1.30 60ft. Would it still be true if that were the case?
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 22 Times in 12 Posts
Try what you have on hand first imo.
If you want a DOT bias tire(slick) , I would look at the Hoosier Quick Time Pros. I've used them for index classes as well as others with success requiring DOT tires.
Mark Mueller FLC |
#8 | |
I lot of the higher HP Stockers are way faster than that on the above tires. We have found very little difference in ET between Goodyears and Hoosiers the last several years. Years ago, the Goodyears tended to not recover from wheel spin very well. However, Goodyear seems to have gotten a handle on that since that time.
From personal experience, I believe M/T makes the best "Big" tire. Had a set of 32x13 hoosiers that were down right awful. I put 14.5x32 MTs on and its been amazing ever since and I get tons of runs out of them. I've also had great luck with Phoenix big tires (radial construction) that came off a SS car like 1320 eluded to. As far as a smallish tire like you are wanting to run, I've heard nothing but good things about the 30x9 Hoosier from all who run it. They work better, live longer, and hold air. At this point, the people that run MT/Goodyear have to be on deals in order to overlook the Hoosiers the way I see it.
Liked 125 Times in 59 Posts
