Liked 314 Times in 113 Posts
It is NOT an UNWRITTEN rule.
Page 21 of the NHRA 2025 Rule Book states "On the other hand, as to performance equipment, it is the general rule that unless optional performance equipment or performance-related modification is specifically permitted by this Rulebook, it is prohibited." Section 11 covering Stock Eliminator under Camshaft/Lifters makes no mention of changing lifter diameter. Therefore it is illegal to do so.
Larry Merk |
#2 | |
Liked 219 Times in 94 Posts
Tony Leonard S/ST 56 S/C 53 |
#3 | |
Liked 734 Times in 385 Posts
Remember max velocity is limited by lifter diameter. So a larger lifter diameter lets you use a cam with a greater max velocity. There is a performance increase in doing that. PS If you look in the Comp Cams Master Lobe List you will see that they have a number of lobe profiles that only will work with a .904" lifter. Stan Last edited by Stan Weiss; 01-23-2025 at 02:29 PM. |
