NMRA / pro media is gone that is why I came over here. We have a local class that is doing well and growing. Looking for a heads up solution. Looked at 9.90 class but when it says a 1000-1300hp car is needed to run 9.90 I am out. My car runs 9.70s with 500 hp. I would look to the sanctioning body to get things under control!
Cheers and happy new year! |
#2 | |
Liked 735 Times in 386 Posts
Yes a go number of years ago people with $$$ come along and decide higher MPH was the way to go, and now it is all about who can run the lowest et from 1000 ft to 1320 without going under. So years ago I had some one ask me to do some simulations for how much HP he needed to run 9.90 in the 153-155 range. Stan |
Liked 759 Times in 379 Posts
This is no heads up class in the NHRA for your car. The 9.90 class is known as Super Gas and it’s a throttle stop class dominated by open cockpit roadsters. Look at the 10.90 class aka Super Street which is typically a backed halved ladder bar or 4 link car but it too is a throttle stop class with many competitors running at least 135mph and many running a bbc making 800-1100hp. In both of these classes, a transbrake and a delay box are the norm. That said, my honest opinion is your car as it’s currently powered won’t be competitive in super street as well.
#4 | |
Liked 3,237 Times in 985 Posts
Just some quick rough calculations. You weight around 2600 lbs car and driver and run around 9.77 @ 136.
If that is the case I get 1000 Foot ET = 9.2043 1/4 Mile ET = 10.9021 1/4 Mile MPH = 133.5387 Stan |
Super Street minimum weight is 2800 lbs.
Liked 1,864 Times in 435 Posts
Mark
I answered the question asked I?m a truth teller if you haven?t heard By the way ?still racing stock
james perrone 1290 STK |
#8 | |
Liked 1,921 Times in 432 Posts
It's a lot harder to run the X.90 heads up classes with a lower HP, lower MPH car, but some people are having some success. Those are the hardest working guys in the classes, though. You really need to be able to drive the stripe, and you need to have your car capable of being deadly consistent.
Alan Roehrich 212A G/S |
OK add some lead 2810 lbs on the stop for .25 less time
1000 Foot ET = 9.1797 1/4 Mile ET = 10.9024 1/4 Mile MPH = 131.6549 Stan |
#10 | |
Liked 397 Times in 153 Posts
Bingo! That's about as accurate as it can be.
Phil Molski PMR Performance S/C 1623 |
