Liked 759 Times in 379 Posts
Sparco says to wash it in cold water and drip
Dry. Simpson recommends dry cleaning them which I have done forever without issue. Last edited by 1320racer; 12-10-2024 at 03:44 PM. |
Liked 882 Times in 236 Posts
I use a product called Molecule Wash . It works great and is safe and recommend for fire suits.
My suit is holding up great and I think it actually is better than dry cleaning. The stitching seems to hold up better. They also have protectant sprays for them stains and odors. Molecule products are available on Amazon.
Liked 704 Times in 281 Posts
I've dry cleaned a couple times. No problems.
Liked 310 Times in 174 Posts
Liked 43 Times in 29 Posts
here is off the G Force website
How would I clean my products? When in doubt, mild soap and water will work with most any product. As for racing suits, wash in cold water and hang to dry. Some manufacturers recommend dry cleaning but to be sure of the chemicals used, you should wash at home. With helmets, a damp cloth and mild soap used to blot the inside of the liner will help remove any built up residue. Belts are susceptible to sunlight and water will speed up the aging process. Be sure to remove or cover belts when washing the inside of a racing vehicle.
Mark Ruset 2048 STK |
