Old 12-09-2024, 03:54 PM   #6
Dirk Olson
Liked 172 Times in 46 Posts
Default Re: 1966 Chevy ll clutch linkage help..
Originally Posted by chopperloco View Post
I have a Super Stock Chevy ll,will be a street strip car for now
SBC with T10 crashbox
Has not been a stick car for many years-I purchased all new stock style reproduction pedal and linkage as a starting point since i had nothing or previous Chevy ll experience..
Car is not quite running yet.I have it all assembled and thought it looked super flimsy and has poor geometry.
It has a fairly stiff non-adjustable Ram clutch-I have only pushed the pedal half a dozen times-the pedal to bell crank bar has already bent!
I guess it would make good sense to replace the upper and lower rods with round tube with rod ends...but any other experience/thoughts?
Thanks
Dom
Unless you are using a Chevy11 block you need to modify the bell crank the get the geometry right. If you are using a non Chevy11 block you will need to make a plate for the pivot ball and start from there. heims are always better but a little more work. Good Luck
Dirk Olson 5036 STK
Dirk Olson is online now   Reply With Quote
