Old 11-14-2024, 05:52 PM   #1
James Perrone
Liked 1,863 Times in 435 Posts
Default Bring back MINESHAFT RULE
If nothing else is gonna change
We need MINESHAFT RULES BACK
This small adjustment will benefit everyone that?s fast and slow
Let?s Go
james perrone 1290 STK
Old 11-14-2024, 07:19 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
Default Re: Bring back MINESHAFT RULE
I agree and make it a function of the weather. Maybe DA less than 500ft and baro of 30.0
Mike Pearson 2485 SS
Old 11-14-2024, 08:11 PM   #3
Paul Wong
Liked 419 Times in 85 Posts
That cant work because it wont take into account any fast altitude track.
The mineshaft rule was a good thing that should be put back in place.
Paul Wong is offline   Reply With Quote
Old 11-14-2024, 08:54 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
I totally agree.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 11-15-2024, 08:36 AM   #5
Mike Pearson
They could have an adjustment factor the Same as they use for the index at altitude corrected tracks. Or just get rid of the altitude correction all together. Then the fast guys could run all out at the higher altitude tracks. I race in the SE so we don?t have any high altitude tracks here. I do agree to bring back the mineshaft rule. Here in Fl we can see DA in the minus readings and baro above 30.30 in the late winter AMS early spring at Orlando and Gainesville. It?s rare though. Typically that type air is 2-3 tenths faster than usual air.
Old 11-15-2024, 10:35 AM   #6
James Perrone
Mike, let?s put mineshaft where it once was when more than half the field Is 80 under whatever it was that?s telling you the weather is good for everybody
When the weather is killer, that?s when you need mine
Let?s go back to what we had
It only comes in effect when the weather is killer
Old 11-17-2024, 01:24 PM   #7
Mike Pearson
I can agree with going back to what it was originally.
Old 11-15-2024, 10:53 AM   #8
west coast
Liked 230 Times in 75 Posts
Here is why the AHFS doesn't work. No body wants to get HP I get it but when NHRA and the manufacturer give bogus ratings on cars and NHRA swipe of a pen or a drunken night on the keyboard and makes the 302 🚀 rockets ships. It needs to be evened out. Not putting runs in the ahfs is not a solution. The mineshaft and Indy not being in the ahfs also the whole Dutch classic this year you cant fix what everybody is complaining about that the ahfs wont work. Let's go back to yesteryear and let officials come up to you at a race and give you hp, because the way it's going nothing will be solved. I don't believe blanket index change will solve anything. The J K L indexs need to be fixed if there are others like this they would also need to be fixed. We need a couple get out of ahfs jail free cards for races on the west coast.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 11-15-2024, 11:04 AM   #9
Yeah, no. Having an individual, basically accountable to no one, have the power to arbitrarily just hand out HP, is absolutely absurd.
A properly formulated system, published openly, is the only way to do it fairly. If people work within the system, well, that's called playing within the rules.
If you're looking for a level playing field, where everyone is always equal, you ain't gonna find it.
Old 11-15-2024, 11:19 AM   #10
JP1738
JP1738's Avatar
Liked 1,306 Times in 359 Posts
We do have Bristol tbf, air blows there, especially in June when they host the national.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
