Old 10-09-2024, 06:43 AM   #51
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Default Re: ET with and without wheelie.
Glenn,
I did and thought that it was one of the best. didn't think the front wheels were that high off the track.
Frank
Most of the fast ones were a foot and a half off the ground. A lot different than prior years.
Old 10-09-2024, 09:14 AM   #52
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Frank when did you last speak to Bill, it’s been several years since I have spoken to him. Back in the 90s and into the early 2000s Bill and I were competitors as well friendly, he joined our Saturday night dinner after racing often.
Old 10-09-2024, 09:15 AM   #53
nickh
nickh's Avatar
Liked 650 Times in 194 Posts
Ed how much clearance do you have from carb to hood with that setup?
Old 10-09-2024, 09:28 AM   #54
1320racer
1320racer's Avatar
Minimal. Basically the height of the Intensity Racing Products carb screen, about 1” to the top of the carb’s main body. That said, the carb gets air off the windshield and the nostrils at the front of the hood.
Old 10-09-2024, 09:35 AM   #55
nickh
nickh's Avatar
Think you could be loosing a little cfm that close to the hood? Have you experimented with a different hood for just a tad more clearance? Just wondering.
Old 10-09-2024, 09:51 AM   #56
1320racer
1320racer's Avatar
I could be. The carb is a custom deal that flows over 1350cfm. As to hoods, I considered it when the car was updated nearly 2 years ago because I wanted to put a taller intake manifold and dominator carb on so I bought 2 hoods, one a Joe Van O pin on cowl hood
the other a VFN hinged cowl hood which I hated and didn't work with our carb location
The Joe Van O hood looked good but a pin on hood doesn't work for how we race. I love the look of relatively quick/fast cars with an OEM flat hood just like my former Chevelle had. I returned the hinged hood but still have the Joe Van O hood which took 5 months to get and is for sale.
FYI, the intake manifold on my engine has been with me since 2007
first installed on the Chevelle’s last engine. It is fully ported, runners extended and the carb pad cut down, done by BCHS for hood clearance and it’s been on every engine in the firebird.
Old 10-09-2024, 10:14 AM   #57
GUMP
Liked 2,354 Times in 554 Posts
Originally Posted by my69396 View Post
How much will a wheelie affect ET plus or nothi?
My perspective is that you need to get all the weight on the rear tire. Since we run performance based classes, we are trying to use ALL the power. On marginal tracks, you can have a hard time if the front end is tied down too much without some kind of power management.
From experience, moderate wheelies don't slow you down at all. I feel that is because aero is not a factor. A monster wheelie will absolutely burn a bunch of ET...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 10-09-2024, 10:26 AM   #58
1320racer
1320racer's Avatar
Originally Posted by gump View Post
a monster wheelie will absolutely burn a bunch of et...
GUMP...knows!
Aero aside, if you get to the 60 foot clocks slower and you WILL, breaking the beam with any part of the car behind the front tires no mind the back tires, you WILL run a slower ET!
Old 10-09-2024, 11:26 AM   #59
KennyAnderson
Liked 357 Times in 119 Posts
Originally Posted by 1320racer View Post
As usual you add nothing of relevance to a thread, you?re a clown!
Now what is preposterous is some here believe that a car can break the 60 foot beams just as quick with the back tires as it can with the front tires!
I do what I can!! LMAO!!
I've driven, owned, or worked on just about everything under the sun. As mentioned, several times in this thread, EVERY combination likes what it likes. Our two stockers are prime examples, the Nova likes a small wheelie, the wagon is faster with a bigger wheelie. There is no hard and fast rule. Testing and more testing will always tell the truth.
KennyAnderson is offline   Reply With Quote
Old 10-09-2024, 11:31 AM   #60
1320racer
1320racer's Avatar
you're clueless!
