Old 10-07-2024, 08:38 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: ET with and without wheelie.
When dead hooking, typically no wheelie will run quicker ET vs. a wheelie breaking the beams with the back tires which will also run a slower 60 foot by about .09.
go to 2:33:00, 5:25:00, 6:48:20 right lane. Despite appearing to break the 60 foot beam with the rear tires, it is not. We dial in the 60 foots with the front shock extension based on DA swing which is everything as it relates to ET and consistency. Our 60 foots for the entire 3 day weekend were 1.26.
Old 10-07-2024, 02:37 PM   #2
Dan Bennett
Liked 595 Times in 136 Posts
I've been sitting here a while deciding whether to post. I honestly could write a couple of pages but will try and keep it as concise as i can.
Though my experience was mostly in a different class, I've had this conversation with class racers a few times. It's probably going to be a very unpopular view here, but in each case I told them that wheelies simply slowed a car down. Every one of them disagreed and told me that stockers and superstockers had to do them. But wait! My opinion is only true if there are no other variables involved.
Think of the force it would take for 5 or six guys to lift the front end of the car to the same height if it was just sitting in the pits. Yes, suspension leverage will reduce that but it's still a question of straight physics. Whatever force is being used to lift the front end could/should be instead transferred to moving the car forward.
But like I said, it's complicated by variables. Forget wheelstands for a moment. Wheelspeed is everything. Period. Higher is better as long as they're driving the car and not losing momentum to excessive spin. So if a wheelie's effect on weight transfer to the rear tires keeps them from going out the window into being less effective moving the car forward, it will be an overall plus.
The people here will forget more than I will ever know about class racing. And it may just not be possible with what you have to work with to achieve tires right on the edge while keeping the front wheels dancing. But physics can't be denied, and that's the ideal case for power to the ground and acceleration.
A different class, but when I'd watch the edges of the slicks quiver all the way through first gear I knew it was going to be a good run.
Dan Bennett is offline   Reply With Quote
Old 10-07-2024, 03:30 PM   #3
jimmyparker
Liked 309 Times in 88 Posts
Back in the eighties I was running a SS/BA Corvette that did big wheelies and was told by most that l needed to calm it down some with limiters, etc. I tried several ways of keeping the front end on the ground but they all hurt the ET so I went back to letting it get pretty high and never looked back.
I would explain my theory but might get beat up by a physics major.
jimmyparker is offline   Reply With Quote
Old 10-07-2024, 03:35 PM   #4
1320racer
1320racer's Avatar
4 decades ago no one built a double adjust shock. Today, they are readily available from multiple manufactures, my choice is Afco and with the turn of a knob
my car launches without any wheelie, dead hooks and runs quicker 60 foot and ET.
Oh and my engine makes more power than yours did and runs a smaller slick than you did.
Old 10-07-2024, 03:59 PM   #5
Dan Bennett
That's pretty much what Kenny Schindler told me and I highly value both your opinions. Being proven wrong is one of the most valuable things that can happen in learning things. It's one reason I went ahead and posted what i did because obviously I must be missing something and would love to know what it is.
It's always frustrating for me to run into things like "that shouldn't work but it does" and "that was a big improvement but I have no idea why". I'm talking about those statements coming from racers I could not respect more and have no need to defend their abilities.
Thinking more about it, I guess even with all the years we've learned new things, there are still a lot of areas in drag racing like that. And I totally understand that when you're on the track, it doesn't matter if you can detail why something is quicker because all that matters is that it is.
Old 10-07-2024, 04:04 PM   #6
1320racer
1320racer's Avatar
but it's NOT!
My Firebird IS a super stock car, built by arguably the best and it DOES ET quicker with no wheelie. The engine under the stock hood doesn't know it's not super stock legal.
Old 10-07-2024, 05:16 PM   #7
jimmyparker
I forgot that my example was 40 years old and no one built good shocks back then but it appears that what worked then is still working reasonably well today but with much better control due to the evolution of shocks.
Exact reason I didn't share my theory.
Bracket cars and superstock cars are two different animals, transmissions, converters, gear ratios, power curves, etc., etc.
Old 10-18-2024, 07:16 PM   #8
Tim Barrett
Liked 472 Times in 72 Posts
Going back to the first question of this post,if wheelies helped or hurt ET's,,Linda and I have definitely done testing for both and in our setup,69 Camaro 350 255hp in G/SA, the results were very impressive. Many might disagree but we found that our multi leaf rear suspension with slapper bars were just as good if not better than the modern day setup that so many run now. Also we found you need a really good front shock and springs to control the lift and landing. We also found a clamp on wheelie bar works great with the setup we have.
Overall,,Linda and I found,with all our computer data,that to much of a wheelie,,bumper scaping,affects et and no wheelie affects our ET and,,low horsepower and lots of horsepower affects ET plus wheel stands. One thing Linda and I know is Alan Rhinehart and Joe Castillo sure do like Stock Eliminator and wheel standing cars.
Tim Barrett is offline   Reply With Quote
Old 10-07-2024, 05:22 PM   #9
MR DERBY CITY
Liked 7,940 Times in 1,520 Posts
Gotta agree with Jimmy on this one …I have been told that during the wheelie it makes the converter work more efficiently …...1320 please do not reply to my post…..I have dealt with enough IDIOTS today and like many on CR I do not give 2 ****z about your opinion OR your (. ) car ……
Old 10-07-2024, 05:29 PM   #10
1320racer
1320racer's Avatar
I don't give a shyt what you think of my opinion or car! You don't know better nor have better!
BS, that's what you want to believe.
