#91 |
Liked 3,232 Times in 983 Posts
Since I have a NHRA.TV subscription I?ve always watched Stock, Super Stock, Comp regularly and have watched Factory Stock and Factory X some but will no longer, what a farce.
#92 |
Liked 397 Times in 153 Posts
What in creation did they DQ Lenny Lottig for?
NOT having anything illegal???
Phil Molski PMR Performance S/C 1623 |
#93 |
Liked 152 Times in 35 Posts
Our lower intake pans which have always passed previous eye and hand measurement inspections, failed the 3D scanner test for having too smooth of radius compared to there as cast intake. Our inspection was done after Q1 so we were unable to make any changes and told DQ for event. Of the 6 FX cars that were there I guess we won the lottery draw as we were the only two who torn down after the run. Hopefully the 3D scanner is going to be used more often as it will clearly make the lines go from gray to black and white. I had no argument other than see you at the next race.
FX L177, FSS L177 STK L177 Lenny Lottig MMPS 77 |
#94 | |
Liked 226 Times in 97 Posts
Tony Leonard S/ST 56 S/C 53 |
#95 | |
If it was, then NHRA would have allowed either a change, or just run it that way ![]()
#96 | |
Guest
Posts: n/a
Fans came for a show, not a four car show. |
#97 |
Liked 759 Times in 379 Posts
The fans didn?t come to watch FX!
#98 |
Liked 57 Times in 19 Posts
Funny thing here is there were 6 cars there. The 2 they inspected were on the same team. Wouldn't it make sense if you're checking 2 cars, you would check one from each team and if one failed, check other team cars?
Did they check and factory stock car intakes with the scanner? Have to really love NHRA. Cant wait to see the scanner used in other classes. The real question is was the scanner paid for with the fines from the US nats disqualifications. The safety safari is going to have some over the top exotic equipment next season with all the fines levied this year. Cant wait to see it #roll-eyes |
#99 | |
Liked 6 Times in 5 Posts
..you should be a laywer...or maybe you are.............. |
#100 | |
that class isnt growing much seems to me...me thinks that the racers that want to put that much effort and money into one of those cars is already racing pro stock...and with the weekly rules pencil dont see it growing much.. |
