Old 07-23-2024, 06:06 AM   #1
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Metric T-200 issue
Originally Posted by Rich Biebel View Post
No cooler and No loop.....plugged at the trans.....Don't know if that could be an issue....
Good morning Rich and to all,
Rich I think you might want to contact the transmission's builder. None of us know who's front pump is in there, and what's been done internally. My McClay 200 is plugged. I believe Leon plugs his cooler inlet and outlet as well. If I remember correctly the Remac front pumps are made to have the cooler lines plugged. But there are other builders out there and some have a different way of getting the same things done. This is where you might want to get in touch with the original builder. If you haven't reached out to Mark Yac. now might be a good time. I'm not personally well versed on all the internal workings of those units to let you know exactly "what " to be looking for.
Have a good day.
Respectfully,
Henry Kunz 1534 H/SA
P.S. Rich have you put a pressure gauge on the trans and run it in gear, even on jack stands ?
Henrys Toy is offline   Reply With Quote
Old 07-27-2024, 08:59 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Red face Re: Metric T-200 issue
Adding fluid did not help
2-3 flare is really excessive and is clearly visible on both the recall tach and datalog from the ECU
I will do more investigation this week to verify the fluid level and the shifter, cable and detent adjustments but I think this trans needs to be gone thru by someone that does them and knows what their doing
Like I said earlier, the men doing them are few and far between....
Rich Biebel
S/C 1479
Stock 147R
Old 07-28-2024, 07:02 PM   #3
SS3860
Liked 164 Times in 55 Posts
Default Re: Metric T-200 issue
Rich, I run a metric 200 built by Thomas Arnett. It has the deep cast aluminum pan and takes 8 quarts to fill with the correct dip stick and tube. Cooler lines are plugged also.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 07-28-2024, 07:34 PM   #4
Tim Barrett
Liked 472 Times in 72 Posts
I had a similar issue several years ago with my Sepanic Metric 200. It was suggested that I shift it into 3rd gear and pull the shifter linkage pin out of the lever on the transmission. When I did I couldn't get the pin back into the lever. I had adjusted the shifter linkage with the transmission in park,,not in 3rd gear. Linkage adjustment is more critical for 1st 2nd and 3rd gear,,especially in 3rd. Never had slippage again going into 3rd.
Glad to see you back!!
Tim Barrett is offline   Reply With Quote
Old 07-29-2024, 08:07 AM   #5
Rich Biebel
Tim, that check is going to happen this week.
I did have the shifter all apart 3 times to change the gate plate and I’m using an air shifter just for bracket racing on an 1/8 mile
That’s just temporary as I know it’s not legal for Stock
I adjusted the cable up top but didn’t do the check at the trans.
I’m going to drop the pan as well as do that check.
At some point I’ll show up and run Stock again.
Maybe the Dutch, thanks
Rich Biebel
S/C 1479
Stock 147R
Old 07-29-2024, 01:34 PM   #6
Rich Biebel
The shifter lever was loose on the trans from wear and a washer that did not fit. I fixed it, it’s tight now
The shifter cable is not in good shape
I bought a spare cable when I owned the car and still have it
It’s going in now
All this stuff is close to 20 years old now so it’s no surprise
It is a zillion times more difficult to work on this car than a dragster that’s for sure.
But I already knew that ! Lol
I need a lift but that’s not happenin !
Rich Biebel
S/C 1479
Stock 147R
Old 07-30-2024, 09:56 AM   #7
curtis reed
Liked 125 Times in 59 Posts
Rich, you don't need a lift, you only need a buddy with a lift. LOL
curtis reed is offline   Reply With Quote
Old 08-25-2024, 07:38 AM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I think this trans needs to be gone thru by someone that does them and knows what their doing..
As you stated a month ago
Old 08-25-2024, 10:18 AM   #9
Rich Biebel
Yes I did and I also said T-200 trans builders are few and far between
That?s the main problem, you aren?t going to be able to get one done in any short time going by what users tell me.
I was hoping for a better outcome but knew i was probably treading water
The way I?ve been driving along with how erratic the car is, a better trans isn?t gonna turn on any lamps
Gotta lot to do before that could happen
Rich Biebel
S/C 1479
Stock 147R
Old 08-25-2024, 10:37 AM   #10
Liked 1,818 Times in 413 Posts
Rich, have you reached out to Thomas Arnett? He would probably work you in if you could get it to him. I know Kentucky ain't a short ride. Thomas is a great guy.
