Liked 544 Times in 213 Posts
Metric T-200, reverse valve body. Trans shifts fine 1-2 but 2-3 shift does not shift solid and rpm flares momentarily....once it shifts, 3rd gear is ok
At the moment I don't have a playback tach configured to visibly confirm this and am going by what I hear. I just raced this car for the first time and it's one I owned back in 2005-2007 and have driven a couple times back in 2011. Never recall having an issue like this. Don't know who built the trans in the car and does not have E-shift..... I have to re-check the fluid level but thought it was ok..... Since it's a reverse shift pattern, it can't be a a shifter cable adjustment issue in my thinking Any ideas from T-200 users ?
Liked 269 Times in 99 Posts
Had this issue with my first 200 changed builders much reduced
Trans builders will know more was told this is something that is inherent. Would think fluid pressure others will know more.
#3 | |
Liked 231 Times in 107 Posts
Liked 170 Times in 56 Posts
I had a similar issue, only with the 1-2 shift. Ended up being the wrong dipstick tube. I only thought it was full.
Tom Flowers E/SA. 3860 |
Liked 189 Times in 48 Posts
Do you have a trans cooler? or a loop
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Rich, Who's valve body is it?
I'll PM you my number in case you don't have it.
Liked 704 Times in 281 Posts
I’ve talked to the previous owner about the issue.
He says it’s always done it and I do know who does transmissions for him but don’t know what valve body he uses. I spoke with 2 other metric users and their experiences with this issue and more importantly the builders that do them and their units do NOT do it. There is no trans cooler I will check the fluid later today and see what it looks like I pretty much am stuck with what I have for now and will make some calls about future possibilities.
#9 | |
Liked 520 Times in 176 Posts
I have a McClay unit in my car currently and it does not shift like that. You being in North Jersey you might want to reach out to Sepanick Transmissions or Leon M. ( sorry for miss spelling ) and they should be able to get you fixed up. You might also want to speak with Mark Yac.as he is a wealth of information on these units. Not having a ton of personal experience with these units myself - it could be a fluid level issue, maybe pan not baffeled. Maybe be valve body or clutch clearance issue, the Servo piston and band , even the direct clutch. If you haven't dropped the pan already, you might want to look inside and see if there is clutch material in the pan. I'm guessing to look over the basic's and go from there. Respectfully, Henry Kunz 1534 H/SA |
Those I’ve talked to with Sepanek built units say theirs do not do it
I will do some checks on it starting later today. It does have a cast aluminum pan on it and it’s always possible the fluid level is not right. The biggest problem with running one of these transmissions is knowledgeable builders are few and far between and the waiting time to get one I’ve been told can be considerable.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 07-22-2024 at 09:25 AM. |
