#21 |
Liked 759 Times in 379 Posts
centering the pads in the caliper relative to the rotor, rotor runout as well the type of bearings, preload on them, type and quantity of grease and seal is how you get your front wheels to spin longer AND it's worth nothing on the time slip. But that's a different discussion for another day.
#22 | |
Liked 125 Times in 59 Posts
Also making sure the caliper is parallel to the disc not just centered. |
#23 |
Liked 4,369 Times in 502 Posts
We are very particular about this and what 1320 mentioned above. Has anyone run DR97 pads front and rear? Does anyone have a certain microswitch they use for high gear to shut off the two-step power? The shifter is Precision shifter forward pattern. Thanks.
#24 |
Liked 81 Times in 45 Posts
I have mounted a switch with a lever on it so when you go to high gear it interrupts the power to the pressure switch. Bobby i have put a few on RJs car. He may even have one. I will do some research on it. The switch would have to normally closed type.
#25 |
Amazon has them. You want one with 3 wire hook up.
#26 |
Yes It would be a normally closed that opens when switched. I just want to see how they are mounted on a shifter.
