Old 05-05-2024, 08:22 PM   #26
djm670
djm670's Avatar
Liked 186 Times in 48 Posts
Default Re: X /Stock ?
Late to the party, I was just looking for something that speaks to the rear axle in a modern 454 Corvette stocker after watching Rylie Trumble at No Problem Raceway today.
Long story short, I built a pro shifted 3 speed transmission for Doolittles X/SA Comet. Wanted to beat Rieder and Wallace for class at 1976 US Nationals, was tired of getting beat by him that year. That was the last year you could run flat out to win. Unfortunately I was not able to talk him out of the car. He did not want to run one of mine as they were all sticks. I should have had a plan to put an automatic in one of them. Anyway, they let me do it the week after Indy with Judy's similar car. Two weeks later there was a stock superstock combo race at Central Michigan dragway. We out qualified W&R by 0.15 seconds. I believe that after indy we were always racing on the brakes, I believe the rule changed the next week. Anyway, we put the trans and clutch set up in Harry's Comet and I drove thru the Summer Nationals that year. We were low #1 qualifier at the Winternationals and all that got us was the opportunity to pull a rod and a piston. Fortunately it was easy to do with a 200 6. I think the best I did with it was get to the semi finals at the summer nationals where I broke out.. and said no more. We used to put restrictor gaskets under the carb to slow it down and at E town we had put the smallest one we had in it before the semi final.
I assume that if one wanted to have a better chance of winning with a slow car, it would be to have one with feedback efi.. to improve the consistancy. We set the record a few times with the stick. I want to say we were around 15.20 or .30 at the 77 winters. I will say it was a fun car to drive. And we never broke anything. The ford 3 speed has the same cluster main drive vertical spacing so you can use 4 speed ford top loader gears, just have to narrow them a bit to get in the 3 speed case.
I don't think I would build a car below f/sa if one wanted to win National events on a fairly regular basis. And with the advent of the Factory stock cars that can go well into the 8 second bracket, that is probably a pipe dream the way they treat tracks today for traction.
My two cents on the subject. Harry's old Comet is still be run today believe it is running in W/S with the advent of front wheel drive cars. And it is still very competitive for class.
djm670 is offline   Reply With Quote
