Liked 16 Times in 11 Posts
Liked 931 Times in 265 Posts
If you are in a hurry, or don't want to spend the money, we've made a similar deal by making a cup type piece the pushrod passes through, pinched under the MC flange, with a washer welded on the pushrod and captured inside the cup. I'll also typically make up a positive stop for the pedal as well.
Liked 7,912 Times in 1,755 Posts
I made note of this "issue" and posted pictures in my build thread "Under the Index for Under a Grand".
Liked 251 Times in 125 Posts
Let me take this a bit further and ask, how does this become an issue?
Does something get inadvertently overlooked during the build, or a repair? When these cars were new, pedal pushrods didn't fall out. I believe the pushrod in some cars is captured in the master cylinder by design. Some have the type that snaps in, as Hacksaw mentioned above. In the latter case, can the driver's foot catch the bottom of the pedal and pull it out? |
#5 | |
#6 | |
Banned
Liked 179 Times in 89 Posts
That happens on GM cars when using a power brake master on a manual brake setup because the recess on the master cylinder piston is shallow on power brake setup and deep on the manual brake setup.
Some aftermarket masters come with a piston spacer to be used only with a power brake booster. |
#8 | |
Aftermarket pushrods are not usually made with the groove for the ring either. Most of the time, the brake light switch, and brackets, are removed on race cars. That acted as a stop for the pedal in OE systems. A hard leaving car can cause a pedal missing a stop to swing back far enough to pull an unretained pushrod out and let it fall down. A new to you car, a car you borrow, a car in your shop, need to be looked at. |
#9 | |
I'm looking for a source for the retaining ring that you mention. I'll post my results. I looked under the dash of my '74 Dart Sport, and I saw what you mention about the brake light switch bracket. It keeps the pedal from being pulled out of the MC. I have an aluminum MC from Dr. Diff. It came with a new retainer ring. When I installed the alum MC in my car (several years ago), I guess I saw that the pushrod is retained by the clip, and the brake light switch bracket. I didn't realize that when a Mopar style MC is installed in something other than a Mopar (or a Mopar without the brake light switch and bracket), it could be installed in a manner that would allow the pushrod to fall out. (Or the driver's foot could inadvertently lift the pedal out of the retaining ring if the brake light switch and bracket were removed on a Mopar.) I hope I'm being clear. I'm not a technical writer, for sure, lol. I was in a street car years ago that lost it's single MC. The driver made a valiant effort using the E-brake and avoiding obstacles until a telephone pole ended our ride. One passenger lost an eye, one had a collapsed lung, I had a back injury that piled on to other back problems my physical working career created. EDIT: Here's a link to Dr. Diff. They have it, and also Detroit Muscle Technologies has it. https://www.doctordiff.com/manual-br...r-grommet.html Last edited by Dave Gantz; 04-07-2024 at 03:19 PM. |
This might be for Mopars only, but here's a picture. The retaing ring is simply refered to as a "ring".
