Liked 90 Times in 52 Posts
After a few points meets & one national event of the new year has the nhra tech team been crawling under automatic equipped cars checking for sfi flex plate expiry dates or asking the driver on their honor is the flex plate up to date or are racers taking photo of of the sfi tag to show tech
#2 | |
Liked 1,943 Times in 584 Posts
Mike Pearson 2485 SS |
I do it like Mike and take pictures. It would be holy PITA for them to even get a clear view of the flexplate tag on mine (904 trans). I had a few choice words for their new rule when I was wrestling the trans out and back in. Someone needs to convince them a Mopar flexplate is a different animal.
Liked 1,436 Times in 299 Posts
I could see them requiring manufacturers to supply racers a sheet with matching sfi stickers like they do for clutches. Then if you just show them the current sfi sticker sheet . They ask for that frequently on clutch cars. Pretty easy as long as you are current.
James Schaechter 3163 STK |
#5 | |
There are SFI flex plates on Ebay or Amazon for under a hundred bucks. Are they real or bogus? I don't know, but getting registration papers to go along with them , either way, might be a real trick. On the other hand, there are what, two or three high tech drag racing clutch guys out there? Of course they are in the thousands of dollar range, and I'm sure they're worth it. I don't see where it would be a big deal for them to provide SFI paperwork. Back to autos... I don't think we need to give them any more ideas here ;-)
#6 | |
Liked 359 Times in 103 Posts
I carry my stickers in the trailer where I hope I can find them if asked to provide them. Just my experience. Rick Cates Canyon, TX |
#7 | |
Liked 130 Times in 43 Posts
When you have the case where you can photograph it and the SFI sticker card with your phone you can show tech the photos with the matching numbers. May be easier to keep track of while keeping the card with the stickers where it won't get lost.
Reid cases also have a Mfg Date and Serial number that is stamped on case and on the card the SFI stickers are on. Quote:
Div 3 Sales, Service and Tech for many manufacturers |
Directly from an un-named NHRA employee there is no plan to do inspections for sfi tag dates at the races unless there is found to be a reason or a need to do so on the flex plates.
The racer signs the tech card certification saying it is good and unless there is some reason to question that you are good. It all falls back on the racer. I feel sure there will continue to be staging lane spot checks for the easy and quick things to check. Rick Cates Canyon, TX |
Liked 231 Times in 107 Posts
A lot easier to just check all the broken pieces laying on track after it comes a part.
Liked 263 Times in 68 Posts
I removed my Mopar SFI flex plate 29.1 dated Dec 2002 and it looks like new. Sure seems like a lot of money to spend when they last so long.
John Dinkel 3295 STK |
